Which Router And Bit? - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-25-2015, 10:33 AM   #1
Rewards Points: 297
Which router and bit?
I need a recommendation on what type of router and bit I need to create an edge matching the attached image. The cut is the same on top and bottom of the edge. I'm working with poplar. I normally buy the best tools available, but in this case I really just need it to do a couple of sills, so don't want to spend more than is necessary to do a good job on these few sills.
Also, the sills pictured have been sitting in an air-conditioned space for a few years. Before I paint, I guess I may need to sand. I have a palm sander, and a random orbital sander, but would hand sanding with a fine grain sand paper work best?
Thanks for any help,
Bob
Bob... is offline   Reply With Quote
Old 09-25-2015, 11:01 AM   #2
Rewards Points: 1,005
best tool for that job is a table mounted router, and guessing a 3/4" cove bit. that diameter appears greater than the 3/8" that it is cut in. router could be hand held if board is clamped securely.
palm sander with 150 will be fine.
TimPa is offline   Reply With Quote
The Following User Says Thank You to TimPa For This Useful Post:
Bob... (09-26-2015)
Old 09-25-2015, 06:42 PM   #3
Stairguy
Millertyme's Avatar
Rewards Points: 508
Box core bit with bottom bearing
Millertyme is offline   Reply With Quote
The Following User Says Thank You to Millertyme For This Useful Post:
Bob... (09-26-2015)
Old 09-25-2015, 07:07 PM   #4
Rewards Points: 1,042
A cove bit is what you need as 1st poster said, core box won't cut that profile, as to size pretty hard to say from looking at the pic, but use a 1/2 " shank bit for sure.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
Bob... (09-26-2015)
Old 09-25-2015, 07:30 PM   #5
Rewards Points: 3,174
Multiple passes with the cove bit.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Bob... (09-26-2015)
Old 09-25-2015, 09:59 PM   #6
Rewards Points: 1,548
Obviously a cove bit, with multiple thin passes given that poplar sometimes chips and or aplinters...but that said, to the orig poster, next time you have a similar issue, Google "router bit profiles" and you will get charts with virtually every router bit in existence along with a profile of the cut that it makes. Ron
ront02769 is offline   Reply With Quote
The Following 3 Users Say Thank You to ront02769 For This Useful Post:
Bob... (09-26-2015), craig11152 (09-26-2015), oh'mike (09-25-2015)
Old 09-26-2015, 12:53 PM   #7
Rewards Points: 297
Thank you for your responses (and thanks for the search term and multi-pass advice ront2769). TimPA mentions a table router, which sounds like the best way, but probably not cost efficient for what I want to do. Could something along the lines of a trim router handle this? If so, are there accessories that I should get (i.e., edge guide, etc.)? And, most importantly, is this a job that a novice should take on? I'm very mechanical and renovated my entire house mostly on my own with help from here and other sources, but am I taking on more trouble than necessary for just a sill or two?
Old 09-26-2015, 01:14 PM   #8
Rewards Points: 118
Lowes has a skill 1.75hp router w/ 1/2" collet for under $70 that's ideal for a few sills. You need a larger base than a trim router has, ideally. The cove bit will have a rub bearing that guides-controls the line of the cut. Edge the bearing rides on needs to be straight and smooth. Small imperfections may "telegraph" into the cut profile.
Do a few practice passes on scrap, let the tool do the work and sand the mill marks from the cutter out of the profile. It'll turn out well.
Wild Willard is offline   Reply With Quote
The Following 2 Users Say Thank You to Wild Willard For This Useful Post:
Bob... (09-26-2015), oh'mike (09-26-2015)
Old 09-26-2015, 01:21 PM   #9
Rewards Points: 297
Thanks Wild Willard. And good timing...I had just decided that I might run to Home Depot or Lowes to see what their offerings were, and you've given me a bit more to go on.
Old 09-26-2015, 02:45 PM   #10
Retired Moderator
Rewards Points: 7,174
All good advice---a 1/2" collet machine will also come with a 1/4" collet---allowing you to use whatever bit you can find---1/2" bits are very popular right now, and are on sale more often than the 1/4" bits.
A table can be made out of a scrap of 1/2" cabinet ply---hole for the bit--base screwed in from below---a straight board clamped for a fence---
Look at 'Woodworking Talk' for home made table plans.Woodworking Talk - Woodworkers Forum
Bob... (09-26-2015)
Old 09-26-2015, 03:28 PM   #11
Rewards Points: 297
Thanks for the confirmation and link. I already picked up the router and am looking at bits now. No 1/2" shank cove bits available at HD or Lowes, so I'm getting a 1/4 shank 1/4 cove bit for now. I won't be doing this til Monday, so I'll check supply distributors to see what's available and bring this back if need be. Again, thanks to all for all the help!
Old 09-26-2015, 03:51 PM   #12
If you decide to go with that 1/4" shank bit, be sure you take very light cuts, the last thing you want is for that bit to snap, and chase you around the shop, here's a link to bits and free shipping.
http://www.mlcswoodworking.com/shops...t=3+4+%22+cove
Old 09-26-2015, 04:17 PM   #13
Retired Moderator
I've been doing router work since the 1960s---I've never snapped off a 1/4" bit--
I do prefer 1/2" bits--but I never had a real issue with a 1/4" one.
Old 09-26-2015, 04:54 PM   #14
craig11152's Avatar
Rewards Points: 1,220
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
Old 09-26-2015, 05:23 PM   #15
Rewards Points: 297
I decided to wait on the bit until monday. The selections were too slim at the big box stores. The best I could find was a 1/4" shank 1/4" cove or a 1/2" shank 5/8 cove. One seemed to big, one (maybe) too small.
@Canarywood1 : Those are about 1/3 of the price of those I saw at HD. Are those decent bits?
