Rotting Porch Columns - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-12-2014, 12:12 PM   #1
Rewards Points: 196
rotting porch columns
I have two columns supporting an 8'x8' porch roof. The other side of the roof is attached to the house. The columns are sitting on cement and the bottom 6" of the columns are rotted. Do the entire columns need to be replaced or can I support the roof and cut out the bad 6" and replace with pressure treated of the same size? I was thinking of adding 5/4 PT wood about 12" high on all four sides of the column, glued and screwed with deck screws to the column and the added piece.
zircon is offline   Reply With Quote
Old 08-12-2014, 12:18 PM   #2
Rewards Points: 18,118
Replace the whole post.
Main reason they rotted out most likely is there not sitting on post bases and are in direct contact with the concrete.
Conceder replacing them with PVC or fiberglass columns.
Any Lowes of HD stock them.
Startingover (08-12-2014)
Old 08-12-2014, 02:13 PM   #3
Rewards Points: 196
Thank you Joe. PVC or fiberglass it will be.
Old 08-12-2014, 05:00 PM   #4
JUSTA MEMBER
Rewards Points: 392
Your way can be done, it is done like that a lot.
Would I do it.
NO, unless the homeowner insisted that I do it.
Otherwise a new fiberglass or manufactured structural post is the way. they never need painting , if you get the right color, never rot again, last longer than I will be around to mess with them again.
And are usually more decorative.
ED
de-nagorg is offline   Reply With Quote
Old 08-14-2014, 10:38 PM   #5
r0ckstarr's Avatar
Rewards Points: 82
I repaired mine 1.5yrs ago. It still looks just as good today as it does in the pictures.
http://www.diychatroom.com/f49/porch...repair-175268/
r0ckstarr is offline   Reply With Quote
porch columns... best lumber Master Brian Building & Construction 4 09-06-2013 06:06 PM
porch columns rotted at the base josephb Building & Construction 2 07-03-2012 10:52 PM
How do I fix my front porch wood columns, that are rotting along the bottom? Kelli.Blazevich Building & Construction 1 03-03-2012 01:04 PM
Replacing Porch Columns mcwolfe6 Building & Construction 8 05-12-2010 07:51 PM
replacing front porch columns rayrgdx General DIY Discussions 4 07-23-2008 06:08 AM
