Right Bit Size For Screw - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-12-2015, 01:39 PM   #1
Rewards Points: 182
Right Bit Size for Screw
How do I determine the right screwdriver bit size for my screw head?
I bought these nails but all my 'Phillips' head bits keep turning within the screw head and messes up the screw head and the bit! - So...
How do I determine the correct bit/head size for a screw?'
http://www.homedepot.com/p/Grip-Rite...vZc2blZ1z0sg0j
tb582 is offline   Reply With Quote
Old 05-12-2015, 02:24 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 29,560
I would expect those to be #2 Phillips. But being #10 screws they could be #3 Phillips.
Old 05-12-2015, 02:27 PM   #3
Rewards Points: 18,118
What ever size fits tight in the hole.
If your using a #2 try a # 3.
What are you trying to drive them with?
Easiest way by far is with an impact driver.
If your trying to use those do install decking there way to long.
Old 05-12-2015, 04:03 PM   #4
Rewards Points: 2,638
Pre drilling a 7/64 hole the length of the screw and grinding the bit tip blunt will solve your problem.
Old 05-12-2015, 06:27 PM   #5
Rewards Points: 196
Dont buy Phillips head.Square and Torxs head screws are alot easier to drive and keep the swearing to a minimum.
HVACTECH96 is offline   Reply With Quote
Sink Size Specs - Advice needed donvaz Kitchen & Bath Remodeling 1 08-12-2012 02:39 PM
wire size for 1575 inverter 15' from battery bluemoonshine Electrical 8 12-28-2011 10:49 AM
Rule of Thumb for Trowel size and Spacer size please.. K.M.G Flooring 7 02-08-2010 09:13 PM
Determining Boot/Register Size Earnie HVAC 15 12-31-2009 06:00 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 01:08 AM
