Recycling Wood From Demolition - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-29-2010, 12:04 PM   #1
Recycling wood from demolition
I am doing a kitchen remodel and just finished demolition. The cabinets were knotty pine. Its still in decent condition, just way out of style. I feel like its a waste to just toss them out. Is there somethign I can re-use them for? Or sell them to someone who can use it? What would you guys do?
Also, I took out a wall with framing lumber that's still in good condition. Not sure if its ok to re-use for framing something else.
acerunner is offline   Reply With Quote
Old 08-29-2010, 01:39 PM   #2
kwikfishron's Avatar
Rewards Points: 68
Put them on craigslist or hang them in the garage.
kwikfishron is offline   Reply With Quote
Old 08-29-2010, 03:02 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
if you have a habitat for humanity rehab store, you could also donate them there.
as long as the framing lumber is in good condition, you can reuse it.
Old 08-29-2010, 03:45 PM   #4
Rewards Points: 111
I'm not big on reusing exterior lumber (don't ask me why), but interior lumber I would definitely reuse if it's not split or bowed. The cabinets would be a cool weekend project to strip and re-stain. Maybe you can make something out of them?
luvdairish is offline   Reply With Quote
Old 08-29-2010, 07:45 PM   #5
thanks, good ideas. didn't think of the habitat for humanity. Though the closest one is out of the way for me.
maybe I'll keep the best pieces of pine and do something with it. They were nailed in, so it was hard to take them all down in one piece. So i have a lot of smaller pieces.
Old 08-29-2010, 08:00 PM   #6
Tom Struble's Avatar
Rewards Points: 2,002
just keep in mind any coating the wood has may contain lead
Tom Struble is offline   Reply With Quote
Old 08-29-2010, 11:10 PM   #7
any way to tell if it does have lead?
Old 08-29-2010, 11:36 PM   #8
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
If you can't use it, it does make good firewood. I forget where I read this, and don't know if it's true, but apparently the carbon footprint of burning something is not any worse then the carbon footprint of that same item decomposing. So instead of letting a big bulky object take up room in a landfill, may as well burn it.
I don't know if what I read was true though, seems kinda odd, I always figured burning was worse. But if it's just wood and no special coating then it's not bad.
Old 08-29-2010, 11:38 PM   #9
you can pickup swabs in the home depot...not trying to scare you,just need to be aware
Old 08-29-2010, 11:42 PM   #10
Rewards Points: 506
I put some old cabinets from the folks kitchen remodel in my basement.
forresth is offline   Reply With Quote
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 08:46 AM
Replacing Carpet on Stairway with Wood jkirby39 Carpentry 3 01-24-2009 01:42 PM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
