Rebuilding An Old Deck - Carpentry - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By Nealtw
  • 2 Post By TarheelTerp
Old 11-19-2018, 04:44 PM   #1
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 3,998
Rebuilding an old Deck
The plan is to use plain vanilla PT (KDAT) 5/4 deck boards.
My question is about the railing.
I really like the look of them INSET and not bolted to the band board.
I dl'ed some pics of what I mean.
Is it worth the extra work? Thanks.
Old 11-19-2018, 04:48 PM   #2
retired framer
Rewards Points: 11,910
Re: Rebuilding an old Deck
You need something around it to support the deck boards. That is not a lot of work. Minutes per post.
joecaption likes this.
Old 11-19-2018, 04:56 PM   #3
HenryMac's Avatar
Rewards Points: 668
I thinks so. Nicely done!
Decks railings tend to get "loose" as they age. Anything you can do now to provide extra rigidity / support will pay big dividends in the years to come.
And using bolts for those attachments will allow you to periodically tighten things up, as the years roll by, when the PT boards shrink... which they will.
I like my projects to be "Hell-For-Stout".
HenryMac is online now   Reply With Quote
Old 11-19-2018, 05:27 PM   #4
MarginallyQualified
That's the selling point for bolting to the bandboard...
but that tightening can be done on the hex nut from the inside too.
If I do the inset I won't see any boltheads.
Probably skin the band with some Trex to dress it up.
I'm with you there.
Thanks for the comments all.
Nealtw and HenryMac like this.
Old 03-13-2019, 07:31 AM   #5
Rewards Points: 1,976
I would never bolt through the main supports on any construction. When your concrete foundation comes out of the ground all the weight should be put directly down on the 4 x 4s through the concrete down to the below the frost line. Your deck is only as strong as your bolt through s. They can loosen over the years and weathering. splitting out and loosening. Your entire construction project is relying on bolts. I have seen so many decks and porches built this way. Some good some bad. Good luck.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 03-13-2019, 07:54 AM   #6
Rewards Points: 1,330
No worries at all with bolts as shown. Makes for a nice sturdy railing.
ront02769 is offline   Reply With Quote
Old 03-13-2019, 08:21 AM   #7
Not talking about railing bolts. Talking about bolts through 4 x4 where it comes out of the sonotube concrete foundation. Looks like bolt through s to hold mains to 4 x 4 instead of just putting all weight directly on 4 x 4s without bolt through s. Drilled holes and bolts interfere with the integrity of the wood.
Old 03-13-2019, 05:26 PM   #8
Big Dog
Drachenfire's Avatar
Rewards Points: 3,810
It is your deck. If you really like the look and willing to put in the effort then it is worth the work.
My Deck Rebuild Progress
Fate whispers to the warrior, "You cannot withstand the storm," and the warrior whispers back, "I am the storm."
Drachenfire is offline   Reply With Quote
Old 03-13-2019, 08:17 PM   #9
Rewards Points: 1,500
Not sure what a couple of the comments have to do with your question...
But yeah I like the look too.. seems much cleaner to me... its not all that much extra effort.. only problem I ran in to when I did something similar on my kids playouse was the deck board splitting when I screwed it down around the post.. like that picture on the top left.. so that little nub that wraps around split right off.. I was too lazy to pre-drill at the time apparently...
ryansdiydad is offline   Reply With Quote
Old 03-14-2019, 06:22 AM   #10
Really a nice looking deck. I read and accept comments. I don't think people t understand how beautiful I think it looks. Many things look great but their only as strong as what's underneath. I can understand if my point is not understood and I am not trying to bring down the nice comments. I was just taught that everything with weight and pressure goes through the structure directly down through the foundation to the frost line. When you Bolt through structural elements your relying on the bolts not the direct downward forces to the foundation. I am sure you all know what crowning is also. If not check it out. Your probably OK because it's a small project and no roof load to add extra weight. Nice DIY.
Pool Deck Cantilever nooneisathome Building & Construction 2 09-20-2014 09:13 PM
Deck Stain? pomlady7 Painting 13 05-24-2014 04:58 PM
Building Floating Deck over ground and Concrete slab jagnew Building & Construction 2 05-27-2012 12:10 PM
Fasten deck board from under deck resonator Carpentry 14 09-20-2010 10:15 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
