Question About Garden Arbor Rafter Tail Proportions - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-10-2018, 06:12 PM   #1
Rewards Points: 34
Question about Garden Arbor Rafter Tail Proportions
I am in the process of building this garden arbor. http://www.arboria.com/products/stru...rosedale-arbor
For the rafter, I am using 2x6 lumber. I am creating a template for the cove cut/routing for the tail. I have measured the lumber width and it is 5 3/8''. For the cove, I have set 4'' (quarter circle) radius, and 1 3/8'' for the rest. I am wondering if this proportion is reasonable. I will do some test cuts to see the results.
Is there any website or link where typical proportions for different tail designs are shown? Thanks.
Also, to connect the rafter to the knee braces will 3'' #10 exterior wood fasteners suffice or should I use lag bolts?
raveon is offline   Reply With Quote
Old 10-10-2018, 07:51 PM   #2
Rewards Points: 272
Re: Question about Garden Arbor Rafter Tail Proportions
Search "rafter tail designs" and go to images. Print out a design you like, and figure out the ratios. Lot of the images have the lumber width so I think you can figure the ratios. Example, if the lumber is 2x6, assume the width will be 5.5", divide the width with half inch span lines.
carpdad is offline   Reply With Quote
Question Regarding - Cinder Block Raised Garden Bed Zyclone Gardening Forum 1 02-16-2015 08:42 AM
add a shower to mobile home garden tub Ray101967 Plumbing 5 01-13-2015 11:18 PM
Rafter tail ventilation question Daugela Insulation 11 05-30-2014 11:26 PM
Quick Garden Shed Foundation Question casper129 Building & Construction 4 04-17-2012 01:40 AM
garden window question viviank General DIY Discussions 4 05-28-2009 08:10 PM
