Question About Fireplaces - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-03-2019, 10:03 PM   #1
i carved this sword
feralfreak's Avatar
Rewards Points: 139
Question about fireplaces
I was looking at pics of fireplace framing, and noticed something i find odd, this time instead of drawing my question i made a cardboard model, excuse my lack of craftsmanship, it looks like something from a tim burton movie, *see attached pic* why is there a gap at the top of the fireboxes? You might notice a wall behind where the face of the firebox is, it's because of a wall that is load bearing which I just did like it was a low door (did a header, just a low one)
Question about fireplaces-20190503_054742_1556938931628.jpg   Question about fireplaces-20190503_053921_1556938964061.jpg
feralfreak is offline   Reply With Quote
Old 05-03-2019, 10:57 PM   #2
Rewards Points: 1,948
Re: Question about fireplaces
I never put one in, but if I did, the first thing I'd check is how to install the firebox and the chimney so nothing will catch fire. If the manual says keep the wood frames some inches away, then it means keep them away from catching fire.
carpdad is offline   Reply With Quote
Old 05-04-2019, 06:24 AM   #3
Retired Handyman/Painter
Johnny_inFL's Avatar
Rewards Points: 1,226
I have installed three "Zero Clearance" fireplace inserts and
even if they have the minimal clearance cavity dimensions, your
local building codes may call for some variations in the framing.
are you going to do an insert ?? or an actual masonry brick and mortar
fireplace ?? your local building codes may dictate the framing involved.
I am thinking that what you are looking at with the air space is actually
a load bearing mini-header which would support a heavy stone chimney
surround above the firebox.
check with your local building codes.
and with the ever changing codes and insurance regulations, if you actually
do want to install a fireplace in your home, you might want to check with
your insurance company as well.
-- Failure is proof that you at least tried ~ now, go do it again, and again, until you get it right --
Johnny_inFL is offline   Reply With Quote
Old 05-04-2019, 06:25 AM   #4
Framing Contractor
Rewards Points: 40
Most of those metal fireboxes require a 2" minimum clearance from wood. I have installed many in the past, but licensing is now required here to install them.
sixeightten is offline   Reply With Quote
Question on code requirements for Split Bus Electrica panel tmittelstaedt Electrical 24 01-26-2019 11:35 AM
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
Plumbing for new shower kit question noviceshock Plumbing 6 03-02-2013 08:11 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
