Pocket Screw Strength For Sliding Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-10-2014, 12:38 PM   #1
Rewards Points: 52
Pocket screw strength for sliding door
I am building an interior sliding door for a mounted track using 1x4 boards (barn door style). I am thinking of pocket-screwing the boards into a 2x4 in which I'll mount hardware to hang from the track. You guys think that pocket screws will be strong enough? It is a 48" wide door, so it is pretty heavy.
I figured the most conservative I could do would be 2 screws per board, one going up into the 2x4 and one coming down in from the 2x4. What do you all think?
boogie81 is offline   Reply With Quote
Old 04-10-2014, 01:14 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 18,430
If you glue it as well....yes....no glue...no hold for long.
ddawg16 is online now   Reply With Quote
Old 04-10-2014, 01:54 PM   #3
Rewards Points: 818
I concur
cibula11 is offline   Reply With Quote
Old 04-10-2014, 07:35 PM   #4
AHH, SPANS!!!
Rewards Points: 1,166
route a groove into 2x4 also for boards to go into
hand drive is offline   Reply With Quote
Tags
carpentry , door , joinery , pocket screws
Pocket door lock christie5683 Carpentry 7 09-10-2012 07:23 AM
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 07:08 PM
Need to replace front door, existing door non-standard size uncle Windows and Doors 1 07-25-2011 06:50 AM
Pocket Door tuchodi Remodeling 8 04-28-2010 03:18 PM
pocket door coming off track jimmy21 Building & Construction 6 10-06-2008 02:28 PM
