Not Sure What To Do About Stone Fireplace - Crown And Baseboards. - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree19Likes
Old 10-06-2018, 06:47 AM   #16
Rewards Points: 190
Re: Not sure what to do about stone fireplace - Crown and baseboards.
Over scribed trim doesn't look good. I'd leave the trim square and fill in with grout.
Johnny_inFL and NGLogik like this.
carpdad is online now   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
NGLogik (10-06-2018)
Old 10-06-2018, 10:23 AM   #17
Ole Wood Worker
BigJim's Avatar
Rewards Points: 134
No disrespect intended, but could you explain why a scribed part would look bad. I may not be understanding what you are saying. The photo below is an example of what I am talking about.
Not sure what to do about stone fireplace - Crown and baseboards.-scribed-flooring.jpg
kwikfishron likes this.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 10-06-2018, 12:00 PM   #18
JUSTA MEMBER
Rewards Points: 162
Jim: if we all had the same taste, we all would live in the same thing.
Kind of like those urban developments where every house is a copy of the next one.
Imagine how bland the world would be that way.
ED
BigJim likes this.
de-nagorg is online now   Reply With Quote
Old 10-06-2018, 12:31 PM   #19
retired framer
Rewards Points: 656
Scribing would be a lot of work, more often you will see the stone laid over a spacer that is removed for flooring or the floor guy undercuts the stone.
Nealtw is offline   Reply With Quote
Old 10-06-2018, 03:05 PM   #20
Ole Wood Worker
BigJim's Avatar
Rewards Points: 134
I agree, it isn't easy, but I just never gave it a thought to doing it any other way when I trimmed a house I didn't contract. If I contracted the house, I installed stops on the sides and at the ceiling so molding and sheet rock wouldn't be a problem fitting.
Ed, you are right, not everyone likes the same things.
de-nagorg and Nealtw like this.
Jim
Old 10-06-2018, 03:42 PM   #21
Two Knots's Avatar
Rewards Points: 4,737
We have a stone Fireplace that the head guy scribed ...
Most people use a compass and pencil...He just used a
pencil and a small stick of wood ...
First he put up a piece of wood holding it up with 2x4's
in the location on the stone where it needed to be scribed.
...then with a small piece of wood with the pencil on the end
he followed the in's and outs of the stone... Then cut the
wood with a jig saw. (it was not hard to do.
A compass would probably be easier.
This is the mantle...its 3 1/2" thick so both the top and the bottom
had to be scribed.
stay tuned for more visual aids.
Behind every clever man is an astonished woman!
*Joann*
Dogs love me, men fear me!
Two Knots is online now   Reply With Quote
Old 10-06-2018, 03:53 PM   #22
Two Knots's Avatar
Re: Not sure what to do about stone fireplace - Crown and baseboards.S
View of both pieces.
*Joann*
Old 10-06-2018, 03:57 PM   #23
Two Knots's Avatar
Re: Not sure what to do about stone fireplace - Crown and baseboards.d
Underneith view after installation.
BigJim, kwikfishron and de-nagorg like this.
*Joann*
Old 10-06-2018, 04:08 PM   #24
Two Knots's Avatar
I took these two just a while ago.
*Joann*
Old 10-06-2018, 04:27 PM   #25
Two Knots's Avatar
Now for the ceiling...I wouldn't scribe the wood...
We filled in the with the same mortar as the stone mortar.
...the side molding where it meets the sides of the stone
is just scribed on the left and right of the FB.
This is the best pic I could get.
For the floor molding in front of the FP, use a piece of
oak wood to match your existing floor?
Do as described...scribe the wood, and finish it to match
the floor and then glue it down.
My suggestion is to just use the width needed ( depends on the
in's and out's of the stone) so that it's
just 1 to 1 1/4" deep X ...about 1/2" high...
it should not be noticeable ...just blend with the existing
floor...
If your interested, I can show you how we installed the mantle
on top of the stone.
*Joann*
Old 10-06-2018, 04:37 PM   #26
kwikfishron's Avatar
Rewards Points: 50
Originally Posted by NGLogik View Post
Now the bottom... when installing the laminate flooring they did not undercut the fireplace.... I’m kind of at a lost in how to deal with it....
You can still undercut it by attaching a gauge to the floor and running a thin disk on a 4" grinder to make the first cut and then with a couple more cuts under that, then the material should chip right out of there.
You'll still have some scribing to do but it doesn't have to be nearly as precise since the flooring will be under the rock.
If you have someone else there with a shop vac by the wheel as you're cutting it will catch most of the dust. I've done it this way more than a few times.
kwikfishron is online now   Reply With Quote
C12LSH or C12FDH or something else for 4" crown and 6" baseboards? Bradeno Tools 10 01-22-2013 11:31 PM
Hitachi C12LSH for Baseboards and crown moulding? Bradeno Carpentry 2 01-22-2013 12:04 AM
Plastic baseboard vs crown moulding baseboards daluu General DIY Discussions 17 01-29-2012 09:05 AM
Baseboards/ Crown Molding/ Casing krombie19 Building & Construction 8 07-14-2011 05:44 PM
Prepping baseboards, crown molding Kooler Painting 6 11-03-2009 01:49 PM
