Normal Mantle Height Above The Floor; 54"? - Carpentry - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By stick\shift
  • 1 Post By chandler48
  • 1 Post By Marson
Old 09-22-2018, 02:16 PM   #1
Rewards Points: 32
Normal mantle height above the floor; 54"?
what is the norm range for how high off the floor a mantle should be? not asking how far above the fireplace opening. I have heard 54". is that 54" to underside of mantle or to the top of mantle? I want to lower it some. I know some of it is preference but I have to sell some day and dont want it too low.
we are mounting a TV over the fireplace. there is no other place in the room to do it, so that decision is made.
even though it will be tilted slightly down, and we sit 12' away, we are planning to drop the mantle a few (4-6) inches to help with viewing angles
there is plenty of clearance above the firebox to the mantle today and would be even if we dropped it 10 inches. when I read "design" sites it says that 54" is standard height. is that 54" to underside of mantle or to the top of mantle?
our ceilings are 9'. the mantle today is wood and is right at about 58" off ground to the top of mantle; 55" to underside. the new mantle will be marble and 6-8" if anyone has that concern. I am thinking 50" to the underside and 52" to the top. sound fair?
Pics (as is) attached. blue tape is where TV would be if we didnt adjust the mantle. thanks
kellytacy1 is offline   Reply With Quote
Old 09-22-2018, 02:39 PM   #2
retired framer
Rewards Points: 14,016
Re: Normal mantle height above the floor; 54"?
If you can find the instructions for a TV over the fireplace. And the one I have seem wanted the top of the mantle 14" above the fireplace and have it something like 8" out from the front of the face of the fireplace.
Before we had to consider the TV we always built the mantle height 48" above the deck that the fireplace was on. Either the floor or a raised hearth.
Old 09-22-2018, 03:14 PM   #3
Rewards Points: 926
If that is an insert, then the manufacturer will have very specific instructions for the height of the mantle, assuming the mantel is combustible. The height allowed will depend on the width of the mantle (i.e how far it projects). No standard height that I have ever heard.
Marson is offline   Reply With Quote
Old 09-22-2018, 03:24 PM   #4
Rewards Points: 3,950
Local codes can come into play as well, best to check with the local AHJ.
Nealtw likes this.
stick\shift is offline   Reply With Quote
Old 09-22-2018, 03:28 PM   #5
retired framer
gas inserts have the wedge on top for combustible and after that they don't care.
Old 09-22-2018, 04:45 PM   #6
Naildriver
chandler48's Avatar
Rewards Points: 2,324
I don't know about any minimum or maximum height requirements, but the triangulation from the opening is described in this. It is showing 31" minimum to the ceiling, so with an 8' ceiling the highest you could go would be 65".
Normal mantle height above the floor; 54"?-mantle_fireplace_min_clearance.jpg
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 09-22-2018, 06:59 PM   #7
Rewards Points: 926
Never heard of that. I've done something like a half a dozen in the last few years, and every one has had something like this:
Normal mantle height above the floor; 54"?-screenshot-2018-09-22-18-56-48.png
Old 09-22-2018, 07:48 PM   #8
Naildriver
chandler48's Avatar
I think Neal is mentioning the overall clearance from the firebox to combustibles as dictated by the triangle stand offs on top of the firebox, not the mantel clearance to the opening in relation to the depth of the mantel.
Nealtw likes this.
Larry......
Old 09-22-2018, 09:10 PM   #9
retired framer
Larry explained it better than I did.
Old 09-23-2018, 11:59 AM   #10
Rewards Points: 926
OK, I see. Don't see how it relates to mantel height, but whatever....
Nealtw likes this.
Floor height and transition between tile & wood floor FirstHome_MKE Flooring 1 11-01-2017 07:18 PM
Peephole Height Solidify Windows and Doors 12 06-23-2015 09:14 PM
9' basement wall ceiling height Bluedeuce Concrete, Stone & Masonry 4 05-09-2015 10:56 AM
Ceiling Height for Beams 6 Inches Below Min Height skobydog Carpentry 10 04-04-2015 02:09 PM
Code for basement ceiling height RDS Building & Construction 3 04-22-2008 10:46 AM
