New Pressure Treated Frame Already Rotted? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 11-14-2017, 09:39 PM   #16
Rewards Points: 66
Re: New Pressure Treated Frame Already Rotted?
Originally Posted by ron45 View Post
At this point you should slope it as much as you can toward the specs.
Proper drainage means you have far less problems in the future.
The plastic is also helpful, so don't forget it.
Really appreciate it. As far as plastic is that interchangeable with a good landscape fabric? In my situation where I already have landscape fabric down and its sloped as above. Would you if you were in my shoes add more dirt to get the exact specs which would be a little tough with all the framing there or leave with the slope I have?
whorneff310 is offline   Reply With Quote
Old 11-14-2017, 11:03 PM   #17
Rewards Points: 5,010
I would try to get it close as possible.
The plastic is best.
Helps water run off, keeps ground moisture from deck, and is grass and weed control.
ron45 is offline   Reply With Quote
The Following User Says Thank You to ron45 For This Useful Post:
whorneff310 (11-17-2017)
Regular floor screws in pressure treated wood Fred_ Building & Construction 17 07-18-2012 09:38 AM
Pressure treated wood color n0c7 Building & Construction 5 07-16-2012 02:06 AM
Cedar Vs. Pressure Treated???? dobrien1030 Building & Construction 15 04-16-2012 09:47 PM
pressure treated wood project -- acceptable quality? bunchofquestion Building & Construction 6 11-09-2011 10:17 PM
Pressure treated wood? sharp Building & Construction 5 04-13-2010 08:50 AM
