Need HELP - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-06-2019, 06:18 PM   #1
Rewards Points: 368
Exclamation
Need HELP
Currently I have removed all the 5/8 particle board underlament to reveal the 1x6 T&G sub flooring.
I have been replacing dry rotted 1X6's and laying down new 5/8 plywood in place of the particle board.
I have been under the house and I am concerned with the way that the flooring was built out.....
The 1x6's are sitting on a 4x8 beams that is spaced out 6ft to center. Was this common practice at one time? should I be concerned with this flooring support?
JPeters is offline   Reply With Quote
Old 02-06-2019, 07:36 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 30,204
Re: Need HELP
1x6 on 6 foot spacing was never a practice. There would be too much bounce.
Can you post some pictures.
Old 02-09-2019, 02:16 PM   #3
Pictures would help.
How far apart are the 1x6s? It's easy to calculate how much sag you could expect in the 1x6s using a tool such as the sagulator:
https://www.woodbin.com/calcs/sagulator/
Depending on how far apart the joists are, you may want to sister in 1x8s, or add blocking between the joists to provide more stability and reduce bounce.
Brian Famous is offline   Reply With Quote
Tags
flooring , framing , insulation , novice , sub-floor
