Need An Additional Plastic Dowel Pin - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-02-2017, 01:15 PM   #1
Rewards Points: 94
Need an additional plastic dowel pin
We have a cabinet that needs another of the plastic dowel pin in order to put up a door on the cabinet. Please see picture. Anyone know where I am able to find one? I've looked at local hardware stores and on-line.
jnstevens is offline   Reply With Quote
Old 06-02-2017, 01:29 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 528
Re: Need an additional plastic dowel pin
Looks like a manufacturer proprietitary pin..... (kinda looks like a shelf pin)
Can't quite imagine how that has to do with a door mount... maybe with some pic's someone will have an alternative idea....
MTN REMODEL LLC is offline   Reply With Quote
Old 06-02-2017, 02:51 PM   #3
Rewards Points: 94
The black plastic pins go on the door on the top and bottom and attach to the shelf where the two black arrows are at
Old 06-02-2017, 03:24 PM   #4
Rewards Points: 2,494
Similar pins are available from HD and/or Lowes or Rockler
Google shelf pins.
bob22 is online now   Reply With Quote
Old 06-03-2017, 08:19 AM   #5
Rewards Points: 492
I don't buy from ikea unless I can modify the hardware. Their hardware changes often enough and do not stock replacements for old hardware. I asked and got a blank look. Book shelf pin holes can be drilled out for regular shelf dowels but if the image pin acts as a hinge, you may not be able to rehang the door unless you disassemble the body.
Check the folding door guides for retracting pins or maybe you can drill a wood dowel and epoxy a metal rod into it.
carpdad is offline   Reply With Quote
How do you seal plastic overflow drain hole on bathroom sink? stouto Plumbing 13 05-10-2016 11:01 AM
Closed Cell Foam, plastic and air space? bokaguy Building & Construction 9 03-05-2012 04:29 PM
What is the best glue for plastic? sukhenkoi Remodeling 3 03-02-2012 08:29 AM
Redgard vs 6mil Plastic Sheeting for tiling amodoko Remodeling 0 01-18-2012 12:57 AM
Plastic - using plastic to make your own replacement parts Hemingway General DIY Discussions 5 09-26-2009 08:49 AM
