Need To Add Headboard To Bed - Carpentry - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By 3onthetree
  • 1 Post By Colbyt
  • 2 Post By mark sr
Old 04-16-2019, 11:14 AM   #1
Rewards Points: 34
Need to add headboard to bed
How do i add a headboard to this queen bed?
Just buy one and screw it? Pls suggest cheap and best way.
Pic attached (top down view near wall) thx
miserkris1 is offline   Reply With Quote
Old 04-16-2019, 11:22 AM   #2
JUSTA MEMBER
Rewards Points: 2,006
Re: Need to add headboard to bed
That is two different requests.
Cheapest, is not the best.
Yes, you have the right idea, first step is to pick what you want to add, then ask how to install it.
See you then.
ED
de-nagorg is online now   Reply With Quote
Old 04-16-2019, 11:38 AM   #3
Hammered Thumb
Rewards Points: 1,130
If that's just a metal mattress frame, as Ed said.
There is no rule it has to be attached to the frame. You can attach anything to the wall independent of it. An old door, pad/fabric over piece of plywood, whatever.
de-nagorg likes this.
3onthetree is offline   Reply With Quote
The Following User Says Thank You to 3onthetree For This Useful Post:
miserkris1 (04-16-2019)
Old 04-16-2019, 12:23 PM   #4
Dave Sal's Avatar
Rewards Points: 728
I made myself an oak headboard last summer as I couldn't find anything decent that wasn't made of wood dust and didn't cost an arm and a leg. I have a Select Comfort bed and frame, and as a result, I had to order the headboard mounting hardware and install it on the frame as there were no attachment points. Once installed, I simply lined up the headboard against the mounting flange, drilled the two holes on each side into the headboard legs, and used long bolts with nuts and washers to secure it to the frame.
Dave Sal is offline   Reply With Quote
Old 04-16-2019, 02:05 PM   #5
Rewards Points: 6,507
Every metal frame I ever saw had a mounting plate on each side and the headboard bolts to that with 1/4 20 bolts of the correct length. Padded legs require a cut in the fabric or the padding will wrap around your bit and possibly tear the fabric. Even unpadded fabric covered ones can do that.
You can use fender washers and HH screws with sharp points on the padded ones.
huesmann likes this.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
Old 04-16-2019, 02:26 PM   #6
retired painter
Rewards Points: 2,136
IMO the simplest/easiest way is to just mount the headboard to the wall.
miserkris1 and Domo like this.
mark sr is online now   Reply With Quote
Ideas for hidden storage shelf behind headboard ben5243 Carpentry 21 07-02-2018 04:08 PM
Electrical in Headboard MIHeart&Soul Electrical 3 07-11-2017 04:54 AM
Diy headboard Nij99 Interior Decorating 3 05-01-2017 03:51 PM
attaching a headboard to a wooden bedframe BP1 Carpentry 2 06-12-2015 09:47 AM
Headboard Question russ4bes Interior Decorating 1 12-12-2009 05:16 PM
