Mounting Handrail - Carpentry - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By BigJim
Old 06-04-2018, 08:16 AM   #1
jkk
Rewards Points: 329
Mounting handrail
I've been asked to mount our handrail on the wall that has drywall hung over basement foundation wall (i.e. concrete). There's 3/4" spacing between drywall and concrete since 3/4" strips nailed to concrete were used to hang drywall. I know we'll have to drill into the concrete wall and use anchors. How do we attach the bracket or medallion without crushing the drywall?
jkk is offline   Reply With Quote
Old 06-04-2018, 08:29 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 29,574
Re: Mounting handrail
Mount the brackets over the strapping.
Old 06-04-2018, 08:49 AM   #3
Rewards Points: 2,652
Consider cutting the drywall out in the area needed, fill in with a wood piece the thickness of the drywall attached to the concrete. Now you have a wood piece to glue a thin shop made wooden escutcheon, with routed edges, to cover that whole area and attach the bracket to those 2 thicknesses.
Old 06-04-2018, 11:24 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 292
You could use a 1x4 with rounded edges and the ends cut on the angle of the rise. Fasten the 1x4 to the lath then mount the rail brackets to the 1x4. Something like the picture below except use a 1x4 instead of a 1x6.
Mounting handrail-bacd69e1e9610c750b95eff8a28ec2ee-stair-handrail-stair-railing-wall.jpg
Nealtw likes this.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Ideas on mounting 4x4 post for handrail. cottageguy987 Carpentry 10 08-04-2017 12:35 AM
Ceiling light with round mounting strap Brandondeth Electrical 8 07-13-2017 09:56 PM
Mounting handrail in brick... mjl1297 Concrete, Stone & Masonry 5 09-27-2016 09:25 PM
Newells, handrail, ballusters gnikyerffej1 Carpentry 1 01-11-2015 07:33 PM
Mounting old handrail on new stair tread vnlilman Building & Construction 1 12-13-2010 05:46 AM
