Miter PVC/wood? - Carpentry - DIY Chatroom Home Improvement Forum
Like Tree8Likes
  • 2 Post By XSleeper
  • 1 Post By Canarywood1
  • 1 Post By XSleeper
  • 1 Post By ChuckF.
  • 1 Post By sixeightten
  • 1 Post By JIMMIEM
  • 1 Post By lenaitch
Old 08-18-2017, 05:41 PM   #1
Rewards Points: 203
Miter PVC/wood?
I am replacing the trim around my garage door. It was suggested by a big box guy that use PVC wood or whatever they call it. I could not get in in a 16' length so I will have to piece together a few lengths of it to cover the top. I was thinking about mitering it to get a better look but I recently read that wood used outside shouldn't be mitered because of climate effects. But this isn't exactly wood...is it? I was not planning to miter the side pieces. There isn't a whole lot on google about garage door trim it that I could find! Maybe I'm overthinking this.
Any tips would be appreciated.
Hurriken is offline   Reply With Quote
Old 08-18-2017, 05:55 PM   #2
Rewards Points: 477
Re: Miter PVC/wood?
When using pvc trim in residential construction, we often use a white pvc epoxy to glue corners and scarf joints together. But that product is not readily available for diyers. You could try PC-11 epoxy, a 2 part mix.
You should miter your corners and scarf any lap joints. Use 2 3/4" t-20 (torx) composite deck screws to attach it. JB water weld putty works well to fill nail holes... or use more PC-11 or Glaziers putty if you like.
Hurriken and lenaitch like this.
XSleeper is offline   Reply With Quote
Old 08-18-2017, 06:23 PM   #3
Rewards Points: 1,042
Re: Miter PVC/wood?
"but I recently read that wood used outside shouldn't be mitered because of climate effects."
Well your not going to be working with wood, PVC trim is a molded cellular product, so miter away.
Hurriken likes this.
Canarywood1 is offline   Reply With Quote
Old 08-18-2017, 07:12 PM   #4
Rewards Points: 203
Re: Miter PVC/wood?
Ok Thanks, good info. Except I don't know what a lap joint is and how to scarf it. Google here I come!
Old 08-18-2017, 07:25 PM   #5
Rewards Points: 477
Re: Miter PVC/wood?
I was referring to a plain scarf joint like this...
http://cf.ydcdn.net/1.0.1.80/images/main/A5scarf2.jpg
(Top image)
Old 08-18-2017, 08:07 PM   #6
Rewards Points: 1,956
Re: Miter PVC/wood?
"I recently read that wood used outside shouldn't be mitered because of climate effects."
True, that's because wood expands and contracts at a different rate in length vs width, so a miter joint outdoors will open and close as humidity varies. Solid PVC does not have that problem.
ChuckF. is offline   Reply With Quote
Old 08-18-2017, 08:22 PM   #7
Rewards Points: 477
Re: Miter PVC/wood?
I don't think that is a hard/fast rule. It would be silly and unrealistic to think that it is. There are many places where wood gets mitered outside. #908 brickmould around a window, for example... or any other moulding with a profile HAS to be mitered.
Good carpentry techniques, backpriming, and continued maintenance (to keep water out) all contribute to mitered joints that last.
Old 08-18-2017, 10:08 PM   #8
Framing Contractor
Rewards Points: 346
Re: Miter PVC/wood?
Any lumber yard near you will have the pvc in 18' lengths. No need to scarf if you don't have to.
woodworkbykirk likes this.
sixeightten is offline   Reply With Quote
Old 08-19-2017, 12:39 PM   #9
Rewards Points: 203
Re: Miter PVC/wood?
I really stink at Miters. Anybody in the market for scrap PVC!
I'll never get better without practice though. I'll let you know how it goes.
Old 08-19-2017, 05:14 PM   #10
Rewards Points: 992
Re: Miter PVC/wood?
What tool were you planning on using to cut the miters? A power miter saw would be quickest and easiest....a manual miter box would work too. If you are going to be doing a lot of DIY work around the house a power miter box would be a good investment. Use PVC glue to put the miters together. As others have said, lumbers yards will have PVC trim stock in long lengths so you won't have to make any joints other than corner miters and butt joints.
PVC is expensive in comparison to wood so might be best to practice your cuts on the less expensive wood.
JIMMIEM is offline   Reply With Quote
Old 08-19-2017, 09:02 PM   #11
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,578
Re: Miter PVC/wood?
big box stores only carry 8's and 12's of pvc,,, lumberyards and siding suppliers will carry 18 ft lengths of it
regarding expansion and contraction.. pvc DOES expand and contract but not do to humidity.. it expands with heat and direct sunlight and contracts in the cold.. so during the winter months mitres will open up. for this reason scarf joints arent recommended becasue they can pull apart when it gets cold when the material shrinks.. google a half lap joint it will move with the expansion and contraction of the wood.
as for adhesive.. clear pvc glue thats for plumbing joints will work, also two part adhesive such as 2p-10 or mitre pro works as well
woodworkbykirk is offline   Reply With Quote
Old 08-19-2017, 09:17 PM   #12
Rewards Points: 203
Re: Miter PVC/wood?
I have a miter box and a power miter saw. I've done some basic stuff with them but it's different when your dealing with an imperfect corner.
I am seriously considering searching for an 18 footer. It would look cleaner as well.
Old 08-20-2017, 06:24 AM   #13
Rewards Points: 992
Re: Miter PVC/wood?
Measure the actual angle of the corner. Divide the actual angle number by 2 and cut each side of your miter to this.
Old 08-20-2017, 06:26 PM   #14
Usually Confused
lenaitch's Avatar
Rewards Points: 116
Re: Miter PVC/wood?
In addition to determining the actual angle you need to achieve, you might want to check the factory settings of your mitre saw. The owner's manual should have the procedure. Some cheaper saws can have a lot of slop in their settings and detents.
If you can't source pieces long enough for your needs, half-lap joints that aren't screwed or glued will open and close in response to the temperature. If you do your cuts and fitting on a really hot day (or on a day of direct sunlight on the surface) the joints will be nice a tight during the summer and open up in the winter, when you are less likely to be outside staring at the them.
lenaitch is offline   Reply With Quote
Ridged Miter Saw Bevel - Can move blade for Bevel cut HTFreak Tools 4 06-16-2015 01:56 PM
Miter Saw Advice (Sliding vs. Non-sliding) theOptimizer Tools 20 01-26-2015 11:29 AM
Picture Frame with Miter Cuts wkumtrider Carpentry 11 01-19-2015 06:55 PM
My FIRST Miter Saw - Seeking Advice CaptainMarvel Tools 24 11-30-2012 11:41 AM
miter bar problem ChrisMohrSr Carpentry 2 02-06-2011 08:47 PM
