Miter Cutting Tall Baseboard Trim - Carpentry - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Johnny_inFL
Old 02-22-2019, 07:54 AM   #1
Rewards Points: 222
Miter cutting tall baseboard trim
What's the smart way to get a clean miter cut on tall (7-9.5") pieces of baseboard trim?
They are too tall for my basic chop saw.
Circular saw set on an angle and run on a rail?
Or are speciality chopsaws made for that? (I'm thinking of those sliding chopsaws. But that's basically just an easier, faster to.use version of setting up rails and running a plain cirrcular saw at an angle no?)
pjstock is offline   Reply With Quote
Old 02-22-2019, 08:02 AM   #2
retired framer
Rewards Points: 5,774
Re: Miter cutting tall baseboard trim
A sliding miter saw is nice but if you have limited use for it, a little expensive.
I would build a jig for the circular saw for the outside corners and cope the inside corners.
Do not use flat bottom gables with scissor trusses.
Old 02-22-2019, 08:05 AM   #3
Retired Handyman/Painter
Johnny_inFL's Avatar
Rewards Points: 1,268
how long are the baseboard pieces ??
how many LF do you have to do ??
the volume of the task often dictates the tools required.
do you have the means to make a small router sled
to keep all your cuts uniform and fit well ???
sort of like the sled jig boat builders use for scarf joints
to join long boards together. except yours will be at a 45* angle.
one option you may consider is that if you have a lot of
90* corners to do, is to make your corners using 3 or 4 feet
long baseboards and scarf them to the longer pieces during
installation. done correctly, the joining seam will be invisible.
sort of like pre-made cove molding corners for the ceiling.
Domo likes this.
Johnny_inFL is offline   Reply With Quote
Old 02-22-2019, 08:11 AM   #4
Rewards Points: 222
excuse my ignorance but what does "cope the inside corners" mean?
I sort of know what a coping saw is, but what is "to cope" something?
Old 02-22-2019, 08:12 AM   #5
Rewards Points: 222
re: router sled.
I don't have a lot of space, expertise or special tools. I'm just trying to finish off a few pieces of baseboard as simply as possible. (I really only have about... 6 corners to miter)
Old 02-22-2019, 08:16 AM   #6
retired painter
Rewards Points: 1,704
Cutting what you can with your miter saw and finishing up with a handsaw is also an option.
mark sr is online now   Reply With Quote
Old 02-22-2019, 08:30 AM   #7
retired framer
The first piece goes in to the corner with a square cut the second piece is cut on the 45 and the excess is cut away with a bit f a back angle and the corner fits every time.
Old 02-22-2019, 08:43 AM   #8
Rewards Points: 8,048
For the few cuts you have you might talk to your local rental store. A sliding miter say would allow you to make a few practice cuts to get nice closed joints. In the real world those inside and outside corners are often not exactly 90 and being able to cheat as needed will make for a nice looking job.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 02-22-2019, 11:16 AM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 590
With a fine tooth blade on your circular saw, you can use a speed square to make the cuts on base molding, and make them fit really tight. I did this years back, and as rough as it sounds, you can make a really good joint this way. I also used the circular saw to make the straight cut under while coping, then used the coping saw to finish the profile.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Debating in my mind about door trim and baseboard replacement... ajwired General DIY Discussions 6 10-29-2018 08:54 AM
Window and door trim width vs baseboard and crown ajwired Remodeling 2 09-09-2018 09:49 PM
Tips for Cutting Baseboards and Door Trim hellothere123 Carpentry 25 10-20-2012 10:40 AM
Door trim miter Slyguysmoke General DIY Discussions 2 03-08-2011 08:43 PM
attaching baseboard trim DIY4EVER Carpentry 11 11-28-2007 01:31 PM
