Measuring For Angled Cuts? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 07-27-2016, 02:15 PM   #16
Rewards Points: 526
Re: Measuring for angled cuts?
Originally Posted by 47_47 View Post
Many of your very short miters seem to be around your posts and should be the same length. Set a stop on your miter saw and use a push stick to hold the short pieces.
Added: Forgot to mention clamp your long piece so it doesn't move.
That was my thinking too, except there are some small variations due to the way the wood has naturally twisted slightly.
"I kissed a light socket once and woke up in a helicopter"
Killavolt is offline   Reply With Quote
Old 07-27-2016, 02:53 PM   #17
47_47's Avatar
Rewards Points: 320
Would be easiest to make one miter on a long piece, put it where it goes. and mark the short point. Do you have a table saw? Can mark the short length, use a zero clearance miter sled and line it up to the kerf.
You can calculate the length by the multiplying the number of outside corners by the trim thickness and adding the length you want to cover. For instance your trim is 1/2" thick and you want to wrap a 3" face, with two outside corners.
2*1/2"+3"=4" long point to long point
Can also secure your belt sander, cut your pieces 1/16" to 1/32" proud and sand to fit.
47_47 is offline   Reply With Quote
Old 07-27-2016, 06:31 PM   #18
recently retired
Rewards Points: 280
What you're attempting to do is to wrap trim around the outside and inside corner. The inside corner is the long point of the miter and can be measured as if it were a square cut. The outside Corner is the short point on the miter, to avoid attempting to calculate what the distance is for the miter cut you can simply hold up a piece of trim and measure from the inside corner to the outside of the trim.
Keith Mathewson is offline   Reply With Quote
Old 07-27-2016, 08:44 PM   #19
Rewards Points: 526
I do not own a table saw, but I really wish I had one, as soon as I get a chance I'm going to buy one.
Should birdmouth cuts be snug against top plate? darsunt Building & Construction 2 07-03-2015 12:45 PM
Measuring woes riptyde General DIY Discussions 12 10-11-2013 12:10 AM
cutting glass bottles and sanding the cuts? jeffsw6 Tools 4 01-10-2013 08:40 PM
How to properly fill stress cuts in concrete before tiling? vseven Tiling, ceramics, marble 20 06-07-2011 09:53 PM
Bad tile cuts krush Flooring 5 06-18-2007 10:15 AM
