Leveling Chair Legs - Carpentry - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 2 Post By Yodaman
  • 2 Post By Nealtw
Old 11-19-2017, 11:46 AM   #1
jkk
Rewards Points: 335
Leveling chair legs
Need to make bottom of chair legs parallel to floor. I'll be placing felt on the bottoms and want to eliminate the current pressure point. Looking for an easy way to trim legs evenly, hoping to prevent having to visit each leg multiple times to get chair sitting on all legs evenly.
jkk is offline   Reply With Quote
Old 11-19-2017, 12:12 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 30,462
Re: Leveling chair legs
Put something on the floor like a thin book or magazine and draw a line around the leg.
Then trim with saw or belt sander to the line.
Old 11-19-2017, 12:59 PM   #3
retired painter
Rewards Points: 1,726
I'd opt for something longer like a strip of plywood or lattice and scribe the line on 2 legs at one time.
mark sr is online now   Reply With Quote
Old 11-19-2017, 01:24 PM   #4
Rewards Points: 9,346
If you have an oscillating tool, take a piece of scrap 1/4" wood, and drill about a 1 inch hole through it. Put the jig on each leg, and cut into the leg with the oscillating tool, all round, but not all the way through. When you have started cuts on all 4 legs, turn the chair over and finish the cuts.
SPS-1 is online now   Reply With Quote
Old 11-19-2017, 02:39 PM   #5
Property Mgt/Maint
Rewards Points: 7,566
Swivel feet for chair legs have been around for 50+ years
https://www.google.com/search?q=swiv...w=1307&bih=621
Dave Sal and de-nagorg like this.
Yodaman is online now   Reply With Quote
Old 11-19-2017, 03:07 PM   #6
JUSTA MEMBER
Rewards Points: 1,460
Turn the chair upside down on a level surface.
Use a rotating laser level setup in the cage, between the legs, mark your lines on each leg.
Then cut each leg with your favorite saw.
But they do make feet for this purpose with swiveling glides.
ED
de-nagorg is online now   Reply With Quote
Old 11-19-2017, 11:23 PM   #7
retired framer
Rewards Points: 5,852
After what ever you do and they are not all the same. tape a 50 grit paper to the floor and adjust by hand.
jlhaslip and de-nagorg like this.
Chair rail and wall boxes Brad Nailer Interior Decorating 7 03-08-2016 06:20 AM
Installing Chair Rail up staircase? tomrash Carpentry 7 07-14-2011 01:42 PM
Unique Chair Rail Obstacle mormegil Interior Decorating 4 06-03-2011 07:56 PM
Re-glued the legs and cross pieces on chair - problem pjenks6668 General DIY Discussions 2 06-10-2010 12:04 PM
