Joist Sistering 2 X 7 3/4" With 2 X 12" - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-15-2014, 12:19 AM   #1
Joist sistering 2 x 7 3/4" with 2 x 12"
1910 duplex home with center 6" x 7 3/4" beam carrying 2 x 7 3/4" x 16' joists
House framing is not platform, balloon framing. Post and beam with 2" x 12" planks supporting a 4" x 7 3/4" ledger/rim joist between floors.
Aside from 2"x2" cleats studded on interior walls for lathe the planks are carrying load of outside walls. It's gutted and being platform framed but I'm now considering using 2x6 studs under 4" wide rim beam that receives all the joists. This will give me 1 1/2" to rest new sistered 2x12s along exterior wall but I'd need to buildup filler top plates below the 4" beam to fit the 2x12s. The center opposite wall I was thinking of just framing a second wall next to existing to accept 2x 12s.
My concern is the 4" rim beam with a 2x6 (1 1/2x5 1/4) studs underneath will force me to leave a 1/2" space between these studs and exterior sheathing 2x12 (planks) if I'm to get that 1 1/2" support for joists ontop of stud wall
Ideas????
Subsidencehome is offline   Reply With Quote
Sistering to correct warped joist... fprawlings4 Building & Construction 2 03-12-2013 09:04 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 09:00 AM
Jacking and Sistering Floor Joist Captain.Sassy Building & Construction 17 08-11-2010 02:30 PM
How to repair floor joist when sistering is not an option jmagee3d General DIY Discussions 2 06-05-2009 03:33 PM
