Jig For Routing Numbers/text - Carpentry - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By SPS-1
Old 10-16-2018, 08:07 AM   #1
Rewards Points: 8,434
Jig for routing numbers/text
I saw this on another forum. Thought it was pretty cool. It consists of only two simple pieces. It creates digits basically like a 7 segment LED display.
Too bad that by the time I need something like this, I will have forgotten about it. But might be useful to someone else here.
Nealtw likes this.
SPS-1 is offline   Reply With Quote
The Following User Says Thank You to SPS-1 For This Useful Post:
PPBART (10-16-2018)
Old 10-16-2018, 09:46 AM   #2
retired framer
Rewards Points: 1,350
Re: Jig for routing numbers/text
That is just too easy.
Nealtw is offline   Reply With Quote
Old 10-16-2018, 03:28 PM   #3
Naildriver
chandler48's Avatar
Rewards Points: 958
You gotta just kiss my grits. Now if he can show us how to do the alphabet. I have a full set of templates and it is easy to do, but this was too simple.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 10-16-2018, 03:53 PM   #4
Works well for numbers (actually, the guy only suggested it for numbers), but I suggest it can be used for text also). Seven segment display does not do certain letters well. For example I suggest "N" can readily be accomplished with two vertical bars using the template, then put down a straight edge to do the diagonal.
