Ikea Table Expansion - Carpentry - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By Jakwriter
Old 11-10-2017, 02:00 PM   #1
Rewards Points: 8
I have the beginnings of a table made from three old restaurant table tops. The tops look to be maple chunks 25mmx 30mm and varying in length from 125 to 250 mm.
I took three of these tops (650mm x 930mm) and joined them on their long sides to make a dining table. As my friend with the joiner pointed out, the grain goes the "wrong" way, across the table. Aesthetically I like it, functionally this means sag.
Since I have a bunch of rough cut maple planks, I thought running a plank (140 to 200mm wide) down the center of the table would solve that sag problem and add awesome to an otherwise boring table. It will be finished with EnviroTex Lite flood coat on top and polyurethane on the bottom. The legs are steel tube welded to plates and independently bolted in 180mm squares at each corner.
My question is, given the finish, do I need to be concerned with expansion? Is the able going to tear itself apart?
Jakwriter is offline   Reply With Quote
Old 11-10-2017, 02:08 PM   #2
Rewards Points: 8
Re: Ikea Table Expansion
Ahh, pictures . . .
Last edited by Jakwriter; 11-10-2017 at 02:10 PM. Reason: 'Cause pictures are worth a thousand . . . You know.
Old 11-10-2017, 05:40 PM   #3
Rewards Points: 9,352
Nice table.
I wouldn't worry about differential expansion. But I don't think that board is going to do much to stiffen it unless you turn it 90 degrees. On the stiffener, you need height, not width.
SPS-1 is online now   Reply With Quote
Old 11-10-2017, 07:50 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 30,468
I don't think it will sag on its own. It might break easier someone was to sit on it in the center.
A leg in the center might be a better choice.
Old 11-10-2017, 08:02 PM   #5
retired framer
Rewards Points: 5,860
Add brackets or something to the posts so you can add a 2x4 skirt under the table. A few angle brackets to attach it to the table.
Old 11-12-2017, 08:43 AM   #6
Rewards Points: 526
Sag usually happens along the grain. That table may break, as pointed, along the glue joint but it helps that the arrangement is more like finger joint. They are used, so if they are flat now I wouldn't think they will sag later. Still don't leave heavy decorations or such 24/7.
You can reinforce the butt joints with glued cleat under the joints. Doesn't have to be edge to edge.
carpdad is offline   Reply With Quote
Old 11-13-2017, 12:54 AM   #7
Rewards Points: 8
Thanks for the input. It seems I was freaking out about expansion/contraction. Due to time constraints, and having a welder and plasma cutter instead of jointer and planer, this is what I went with . . .
Just about doubled the weight, but now their baby can sit on it until he's a teenager.
Thank you again. Ya'll will be hearing from me when those maple planks get turned into ANOTHER table.
joed and Nealtw like this.
How to ... Antique Table and Chairs Restoration? Howitzer General DIY Discussions 13 11-25-2014 09:32 AM
Running pool electric alten78 Electrical 14 06-26-2011 07:06 PM
Sizing Motor Branch Circuit Conductors and OCPD's electures Electrical 5 06-23-2011 12:32 AM
IKEA vs Other Prissy General DIY Discussions 3 05-28-2009 10:23 PM
Help please with table support Stonefury Carpentry 2 01-07-2009 02:05 AM
