Ideas To Correct A Short Deck - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-27-2015, 03:50 PM   #1
Rewards Points: 4
ideas to correct a short deck
Hello
recently my above ground pool collapsed. when the pool company installed the replacement pool ( 52" in height) the deck around the pool is now 7.5 " lower than the pool and there is an empty space of about 5.5 inches between the deck and the pool top rail.
Any ideas on how to correct this?
I greatly appreciate your input.
adelko is offline   Reply With Quote
Old 06-27-2015, 04:42 PM   #2
JUSTA MEMBER
Rewards Points: 302
Build yourself a wide walkway atop your existing deck, to fill the gap between the deck and pool, and to make a level area around the pool at pool height. This will make a step down from pool height, to deck height, and solve the problem.
Or build an entire new deck at the pool height, you did say that something has collapsed.
ED
de-nagorg is online now   Reply With Quote
Old 06-27-2015, 05:17 PM   #3
Rewards Points: 18,118
Hard to say how to fix something we can not see.
Old 06-27-2015, 06:11 PM   #4
Rewards Points: 4
here is a picture of the pool and the low deck
Old 06-27-2015, 06:52 PM   #5
kwikfishron's Avatar
Rewards Points: 60
How about some pictures from underneath showing the framing (no closeups needed).
It's very possible that the deck could be jacked up and the supporting post replaced with longer ones.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
oh'mike (06-27-2015)
Old 06-27-2015, 07:25 PM   #6
Property Mgt/Maint
Rewards Points: 7,072
I would remove the current deck boards. Thoroughly inspect the footings, posts, beams, and joist. If its worth saving, tune-up as necessary tightening screws, bolts, and anything loose. I would also take the opportunity to stain the existing support structure while it is accessible.
Next raise the joist structure 7.5 inches by adding new treated 2 x 8 joist on top of the existing. You should be able to place your new joist directly on top of the old. Cantilever the pool side joists to make up the current 5.5" gap. Tie the new and old joists together with either steel mending plates or make your own using 1/2" treated plywood. Re-deck with the same thickness of boards that you removed and you will be 7.5 inches higher.
NO Diving (yea right!)
[political signature removed]
Yodaman is offline   Reply With Quote
The Following 2 Users Say Thank You to Yodaman For This Useful Post:
Dave Sal (06-28-2015), de-nagorg (06-27-2015)
Deck design ideas for strange shape sunken patio kemperflow Building & Construction 0 05-05-2014 04:56 PM
Miscellaneous deck questions NewHomeDIYGuy Building & Construction 38 09-17-2012 03:41 PM
Deck Joist Cut Too Short Artemis2007 Building & Construction 6 07-14-2012 02:18 PM
How to correct deck footing DirkPitt Building & Construction 0 08-10-2009 05:39 PM
UGH! just realized one of my deck posts is cut too short nasdaqer Carpentry 8 06-19-2007 08:26 AM
