Idea For Interior Sliding Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-04-2014, 04:34 PM   #1
Rewards Points: 934
Idea for interior sliding door
We would like to put a nice looking sliding door in here but now sure where to start, how to make it or where to buy it. I would rather make one but need some pics to get an idea. I tried googling but with not much luck. Any ideas or pics would help. Thanks
Idea for interior sliding door-image-4271250962.jpg   Idea for interior sliding door-image-173294564.jpg
Mstrlucky74 is offline   Reply With Quote
Old 05-04-2014, 05:48 PM   #2
Rewards Points: 18,118
Why does that area even need a door?
Google pocket door.
Old 05-04-2014, 06:24 PM   #3
Rewards Points: 582
check lowes for interior french doors ..would look nicer than a sliding door...you could frame to suite...
The Following User Says Thank You to ben's plumbing For This Useful Post:
joecaption (05-04-2014)
Old 05-04-2014, 07:07 PM   #4
Rewards Points: 934
Google pocket door.
Would like to have some privacy.
The Following 2 Users Say Thank You to Mstrlucky74 For This Useful Post:
ben's plumbing (05-04-2014), kwikfishron (05-04-2014)
Old 05-04-2014, 07:12 PM   #5
Rewards Points: 934
Unfortunate that would not work for us.
Old 05-04-2014, 07:19 PM   #6
Rewards Points: 582
just what are you looking for .....if you don't have room for a standard door opening size....or do you just want a slider.......what is height and width of your opening..
Old 05-04-2014, 07:20 PM   #7
Why?
A sliding door is going to take up that whole wall to the right of the picture.
Removing all the studs, adding a long header, a whole lot of sheetrock repairs.
A double French door would be a really simple install.
Just trying to understand your thinking.
Old 05-04-2014, 08:45 PM   #8
Rewards Points: 934
Why?
Don't want doors that swing open. Might do a barn door.
Old 05-04-2014, 08:51 PM   #9
kwikfishron's Avatar
Rewards Points: 72
A barn door type of tract is what I was thinking.
kwikfishron is online now   Reply With Quote
Old 05-05-2014, 11:45 PM   #10
I would go with a barn door over a pocket door.
You can use just about any door you want for a barn door. Some of the tracks do get a little pricey. You may also need to frame in a header across the opening to have something to attach the track to depending on what you do.
Last edited by kwikfishron; 05-07-2014 at 11:53 AM. Reason: Removed Website per forum rules
uncommon doors is offline   Reply With Quote
Old 05-06-2014, 01:02 AM   #11
Rewards Points: 83
Do you want visual privacy, sound privacy or both? I look at that and think the simplest solution (for visual privacy, at least) would be a curtain on a tension (or permanent) rod. could be a split curtain with fancy tie-backs. As fancy and nice as you might want. Just a thought.
Missy Bloom is offline   Reply With Quote
Door frame resize conflicts with anchor bolt colossus610 Building & Construction 8 09-22-2012 11:28 AM
Exterior Door Leak around Weatherstrip/Frame not Plumb woodardhsd Building & Construction 9 09-01-2011 06:17 PM
Security screen door dangerp Carpentry 4 09-22-2010 08:02 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 09:43 AM
