How To Join Top Shelf To Side Boards In Closet? - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-01-2013, 04:37 PM   #1
Rewards Points: 28
How to join top shelf to side boards in closet?
Hi there,
I'd like to build a closet shelving case using predrilled laminated boards at HomeDepot. I'm trying to figure out how to join the top & bottom shelf to the side boards.
I took a picture of my existing closet cabinet. The top & bottom shelves are screwed to the side boards. As you can see in the picture here at http://i44.tinypic.com/1zmmiky.jpg. But I don't know what this type of screw is called. Can you help identify it? Or do you have other better ways to join the top & bottom shelf to the side boards?
Thanks!
Lily
LilyT is offline   Reply With Quote
Old 10-01-2013, 04:56 PM   #2
You'll find at HD and Lowe's little metal pegs that are intended to be inserted into the holes in your cabinet. They'll have a short piece which will stand proud of the wall....your shelf will sit on the peg. Four for each shelf.
They're designed with all the holes so you can decide how many and how much space between each shelf
RoyalAcresRod is offline   Reply With Quote
Old 10-01-2013, 06:20 PM   #3
Rewards Points: 28
That you for the reply! But the pegs you mentioned are for the adjustable middle shelves. I want the top & bottom shelves connected to the side boards permanently. I'd like to find out what type of the screw is used here to attach the top shelf to the side boards.
Old 10-01-2013, 06:50 PM   #4
Chances are that those....sigh, I can't recall the name. They're designed to connect two perpendicular pieces of wood together. If I'm seeing what I think I am.
Big box store will have some. Also, Kreg screws would work.
Old 10-01-2013, 09:25 PM   #5
Renovating My Land Yacht
Rewards Points: 616
Is it a cam lock screw I know the box stores have these. ?
forcedreno2012 is offline   Reply With Quote
Old 10-02-2013, 12:38 AM   #6
Rewards Points: 28
It is cam lock and bolt! Thank you so much!
Old 10-02-2013, 06:04 AM   #7
Thank you, Reno. The name had escaped me
The Following User Says Thank You to RoyalAcresRod For This Useful Post:
forcedreno2012 (10-02-2013)
Tags
closet , join , joint , mdf board
Wire closet shelf coming out of wall... Iluv4cats General DIY Discussions 16 01-15-2009 06:39 AM
Any experience with Dupont Real Touch elite laminate flooring? danidisney Flooring 12 08-24-2008 04:22 PM
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 05:42 AM
Side By side refrigerator Susie Q Appliances 6 08-31-2007 04:26 PM
linen closet shelves question pacifier1er Carpentry 3 06-25-2007 04:20 PM
