Thread Tools | Display Modes |
#1 |
Rewards Points: 752
![]() How to fix a door closer
I have a door that has a ball closer on the top of the door that slides into the closer on the top of the casing.
The ball portion does not protrude out far enough to keep the door closed tight when it slides into the other portion in the casing. How is the ball portion held into the top of the door? Do I just pry it out and reinstall a new one? That easy? |
Sponsored Links | |||
Advertisement |
#2 |
JUSTA MEMBER
Rewards Points: 368
Is this a pocket door?
that unit in your picture is a pressed in item, it just pries up and out. sometimes it's mating surface gets knocked out of alignment, see if it can be adjusted to keep the door closed tighter. ED |
Advertisement |
#3 |
Rewards Points: 4,796
Push the ball in, if it feels stiff then that's not your problem. Should be a spring under the ball.
Advertisement |
#4 |
Rewards Points: 2,616
It looks as if it's way past due for some WD-40 followed by a dry graphite lube.
#5 |
Maybe I'm seeing a couple of notches for a spanner to adjust height.
The Following User Says Thank You to SeniorSitizen For This Useful Post: |
oh'mike (11-20-2014)
#6 |
Retired Moderator
![]() Join Date: Sep 2009
Rewards Points: 7,174
The ball mechanism screws into the mounting sleeve---to raise it up--unscrew it a turn or two---
New members: Adding your location to your profile helps in many ways.--M-- |
#7 |
Rewards Points: 1,005
not sure of door style here, but is it possible that the door is sagging?
#8 |
Rewards Points: 752
Just turn the ball mechanism to raise up or down?
#9 |
Rewards Points: 752
If it is the door sagging, do I need longer screws to pull the door up?
#10 |
if it is a door hung on hinges, then the hinges may need looked at. several things can make a door sag:
the door joints become loose and the door racks out of shape, the house settles and the door jamb/frame gets out of shape, or the hinges loosen. evaluate these things and the gap around the door. make sure the screws are securely fastened. often you can place cardboard shims under the bottom hinge to give the door a lift back into alignment. |
#11 |
Rewards Points: 141
yes...yours is a slightly different style, but this image shows you the threads, and how the ball part moves. you can use a small screwdriver and hammer ( gently ) the mechanism around.
Advertisement |
Thread Tools | |
Display Modes | |
