How Do I Adjust Hinges? - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-07-2014, 04:30 PM   #1
Rewards Points: 752
How do I adjust hinges?
How do I adjust the range of motion for the attached hinge? It opens too far and hits my wall constantly. How/can I adjust the hinge so it has more limited range? Thanks!
kennykenny is offline   Reply With Quote
Old 12-07-2014, 04:32 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 266
The adjustments on that hinge aren't for limiting the swing, the adjustments are for position of the door on the cabinet.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 12-07-2014, 04:42 PM   #3
MT Stringer's Avatar
Rewards Points: 254
The hinges are sold with different degrees of opening - 105, 110, 120, etc. I don't have any idea of what those are.
But, you could change em out for new ones if you can figure out what the offset is.
MT Stringer is offline   Reply With Quote
The Following 2 Users Say Thank You to MT Stringer For This Useful Post:
BigJim (12-07-2014), jaydevries (12-07-2014)
Old 12-07-2014, 04:55 PM   #4
Rewards Points: 752
Great information. What do you call these types of hinges?
Old 12-07-2014, 05:28 PM   #5
Rewards Points: 18,118
European style hinges.
If there hitting the wall then someone messed up and did not add a spacer between the wall and the cabinet.
Cabinets are never mounted tight to a wall.
Old 12-07-2014, 05:32 PM   #6
chitownken's Avatar
Rewards Points: 510
You're going to want a range of opening as close to 90 as possible.
chitownken is offline   Reply With Quote
Old 12-07-2014, 05:45 PM   #7
Doc Sheldon's Avatar
Rewards Points: 400
That looks like a Blum compact, which I think 107 degrees is as close as you'll find to 90.
They do have a mini that goes down to 95 degrees... but I don't know that it'd swap out.
http://www.blum.com/us/en/01/20/20/#BROCHURE1 Page 12
Page 56 of that brochure gives you all the ranges, too
Doc Sheldon is offline   Reply With Quote
Old 12-07-2014, 08:12 PM   #8
Rewards Points: 638
you need a blum hinge restrictor clip order under 5 dollars unless you have to switch hinge out if they do not have one for the hinge you have
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 12-08-2014, 10:20 PM   #9
Rewards Points: 752
I'm having difficulty finding the exact kind of restrictor clip for my use. The video shows a soft close hinge. My hinges are not soft close. I'm not for sure of the manufacturer of my hinge to be able to source the exact restrictor that I need. Any ideas? I have contacted a few local wood working stores that are local to me and they have not heard of anything that restricts the door opening. Thanks!
European Hinges for Curved Kitchen Cabinets thiftyspender Carpentry 2 04-20-2016 09:00 AM
Multi adjust door hinges on glass doors hansi General DIY Discussions 2 07-20-2010 08:20 AM
Space for hinges on custom closet doors nrk411 Carpentry 3 07-11-2010 08:34 PM
Blum hinges from 15 years ago?? MI-Roger Carpentry 14 02-23-2010 01:44 PM
Cabinet hinges don't fit... arghhhh!!! pisces7378 General DIY Discussions 7 12-25-2009 08:47 PM
