Hold Up 3200lb Of Dirt On Shed Roof - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-09-2015, 07:53 PM   #1
Rewards Points: 6
Question
Hold up 3200lb of dirt on shed roof
I want to build a 4'X8' shed with a on the garden roof.
I will have a 4'X8' box 10 or 12 inches deep on the roof full of earth.
I was told that each square foot would weight 100lb when the earth is wet.
I live in Montreal so I must also consider 3 feet of snow/ice in winter that will accumulate on it.
My question is what size 4 foot long beams do I need and how many do I need (spacing over the 8 feet) and what size standing beams (2X4, 4x4 or 6x6) do I need and how many (spacing over 8 feet on each side)
Or if you already have a shed plan with a green roof to show me that can hold the weight, I would be most appreciative ! Thank you !
OldHouseRenov is offline   Reply With Quote
Old 04-09-2015, 08:32 PM   #2
Retired Moderator
Rewards Points: 7,174
We have several engineers here---one will be along soon--
As a structure---that is not a lot of weight --so it can be done safely---without huge cost.
Old 04-12-2015, 05:28 AM   #3
Rewards Points: 12
Roof is easy, what are you planning for the walls?
Neosastan is offline   Reply With Quote
Old 04-12-2015, 09:31 AM   #4
Civil Engineer
Rewards Points: 5,246
It sounds like you need to design for at least 100 psf for the soil load (probably should use 120 psf), 40 psf for the snow load, and 10 psf for material. There is a calculator at this location http://www.awc.org/calculators/span/...rcalcstyle.asp
that can help you out. Unfortunately it does not work up to the full loads you have, but it is close, and you can size to the next larger lumber dimension to be conservative.
Old 04-13-2015, 10:47 AM   #5
Rewards Points: 6
So If I used/understood correctly the tool, the lumber below should hold safely even with a 200lb man walking on the roof to harvest his herb garden ?
  • For the roof
  • 2X8 5feet across (so 8 of them 12" appart) with 3/4 plywood on top
  • And the walls each side holding the roof up
  • double 2X12 8feet across resting on six(6) 4X4 each 16inches apart (8 feet tall on one side to 7.5 feet on the other so to give 0.5' pitch to the roof)
Old 04-13-2015, 11:17 AM   #6
Rewards Points: 6
Hi and thank you. I am new to this forum and still learning how it works. I replied to my own post. Can you let me know if it is correct?
Tags
backyard , build , roof , shed , weight bearing
installing a metal roof on a shed will02 Roofing/Siding 15 04-08-2014 03:41 PM
Ceiling joists with shed style roof? agent008 Building & Construction 3 09-29-2013 02:30 PM
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 04:17 PM
add shed roof to gable roof lucy1 Roofing/Siding 0 10-30-2011 09:31 PM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 08:28 AM
