Hickory Flooring - Carpentry - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By chandler48
Old 07-10-2019, 08:25 PM   #1
Rewards Points: 12
Hickory Flooring
I am installing 3/4 x 5" random length hickory hardwood flooring. When I nail the short ones down, in my next row I will use a longer one and it draws the board in tighter and causes a gap.. I have tried different nailing patterns and it still causes a gap. It's not a large gap but it just doesn't look right. It gets very frustrating. Is there a solution to this problem that anyone would suggest? Would really appreciate some helpful advice. The small ones run about 16 inches to 22 inches that I am referring to. Thanks again.
pappaw903 is offline   Reply With Quote
Old 07-11-2019, 04:41 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 4,304
Re: Hickory Flooring
Can you post pictures so we can see what you are seeing?
Dave Sal and de-nagorg like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 07-11-2019, 02:56 PM   #3
Rewards Points: 1,926
One thing I would check is the board widths.
I have read that the shorter boards are sometimes about a 1/16th of an inch to narrow or too wide.
And some of the longer boards are too wide by 1/16the of an inch.
But I do envy your hickory. I wish we could have used it. Since we have under floor radiant heat, we were told that only an engineered floor would work well and we found a great deal on Acacia.
The only stupid question is the one you DON'T ask!
ktownskier is offline   Reply With Quote
