Help With Asymmetric Doorways (moulding) - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-17-2016, 11:57 AM   #1
Rewards Points: 8
Help with asymmetric doorways (moulding)
Attached is a picture (strangely rotated) of my problematic doorway. We are refinishing a living room, and there is also a normal doorway on the same wall. The three options we are evaluating for moulding are 1.) Simple mitered casing, 2.) Rosettes, 3.) A capital. On the full doorway, we are fans of the capital, but don't know if that would look ridiculous with one side ending flat against the perpendicular wall. Any advice?
tomkat364 is offline   Reply With Quote
Old 05-17-2016, 12:31 PM   #2
Rewards Points: 388
Re: Help with asymmetric doorways (moulding)
Are you talking about the actual door or the opening on the green wall? if the green wall, I would go for option #4, leave it as is.
As far as ending the molding against a wall, it looks wonky. Here is a pic from my bathroom I am redoing. It will looks less ridiculous when it is painted.
1acre is offline   Reply With Quote
Old 05-17-2016, 01:30 PM   #3
Rewards Points: 8
I am speaking of the opening on the green wall. The drywallers were not incredibly talented, and we were planning on dressing it up. Current plan was to line the inner surfaces with thin plywood, mimicking a door jam (again, sans door), and then putting casing around to frame it. This would work well on the full cut out in the other section of the same wall, but not sure how to handle this opening which hits the perpendicular wall.
Old 05-17-2016, 04:01 PM   #4
Rewards Points: 388
IMO, to make it look not crazy, you'll have to build out what is the right side in the picture a bit to accept some casing on the right side. Therefore, loosing some of the doorway.
Old 05-17-2016, 06:15 PM   #5
Rewards Points: 18,228
Do not plywood for jambs, the end grains will show.
1acre's suggestion is the way to go on this one if your going to use casing.
I'd just leave it the way it is.
OK moisture barrier? -- Painted, caulked moulding instead of tape/spackle metazone Kitchen & Bath Remodeling 13 01-05-2014 09:40 PM
removing paint then staining moulding n0_oNe Painting 2 03-18-2012 09:19 AM
Crown Moulding Paint Peeling ryanb4614 Painting 6 01-23-2012 10:15 AM
Door Moulding Idea Help Vibber Carpentry 4 06-01-2010 08:51 AM
Crown Moulding and nailing davis_mc Carpentry 21 01-12-2010 11:52 PM
