Gap Between Door Trim And Jamb - Fix? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree6Likes
Old 05-11-2019, 05:56 AM   #16
retired painter
Rewards Points: 2,126
Re: Gap between door trim and jamb - fix?
We're having a house built and have had some issues with some of the subcontractors
Are you the GC or are you did you hire a builder, if the latter it's his problem. Just point it out and make sure he fixes it before you write another check. If you are the GC it falls more on you especially if the carpenter is unwilling to come back and fix it properly.
mark sr is offline   Reply With Quote
Old 05-11-2019, 07:00 AM   #17
Naildriver
chandler48's Avatar
Rewards Points: 2,094
Aside from the slamming, it appears, since these are prehung doors, that the clamshell was not set flush with the finished wall. Not knowing the thickness of the finished wall puts all the pundits in the back seat. A jamb extension is needed if the clamshell is not adjustable. True, too, one person may have installed the doors and another the trim, so the door installer just missed the plane needed to properly allow the trim to rest flush.
Regardless, it needs attention by the installers, whether you call them trim carpenters or finish carpenters or hacks. If it is a new house, the GC needs to be held accountable.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 05-14-2019, 04:34 PM   #18
Rewards Points: 1,112
Originally Posted by Domo View Post
How can the inspector pass this crap?
Inspectors are not involved with the finishes, they can only inspect items that affect fire and life safety and energy and are legally codified.
Anti-wingnut is online now   Reply With Quote
Old 05-14-2019, 07:31 PM   #19
Contractor/Engineer
Rewards Points: 1,036
Yes, you are correct...
Too bad my wife wasn't there...
Nealtw likes this.
Domo is offline   Reply With Quote
Old 05-15-2019, 04:46 AM   #20
retired painter
The only thing that type of workmanship does with an inspector is make him look closer at the work he does inspect. He can't turn down a job because the finish work looks bad.
Nealtw likes this.
Old 05-15-2019, 11:17 AM   #21
Except about the only time the inspector sees the finished trim is on final, when there really isn't much to inspect anyway.
Flushing jamb up with wall for casing danielrg Windows and Doors 6 05-20-2014 10:43 PM
Door Jamb width jam Haggis Windows and Doors 4 03-27-2014 08:32 PM
PVC to bottom of exterior door jamb jjrbus Carpentry 8 05-10-2013 01:35 PM
window jamb extensions too short. ideas? itsnotrequired Windows and Doors 5 04-24-2012 04:22 PM
Reducer scribed to fit door jamb? Please Help!! joemontana16 Flooring 1 03-14-2010 10:47 AM
