Gap Between Door Trim And Jamb - Fix? - Carpentry - DIY Chatroom Home Improvement Forum
Like Tree6Likes
Old 05-09-2019, 08:13 PM   #1
Rewards Points: 16
Gap between door trim and jamb - fix?
We're having a house built and have had some issues with some of the subcontractors. A couple of weeks ago they put in the interior doors. The last couple of days the trim crew has been in, putting in the door trim, baseboards, etc. Tomorrow the interior painting and caulking is supposed to get started.
Problem is, almost all of the doors have a big, varying gap between the frame (jamb) and the trim. By "varying" I mean it will be nice and tight at the bottom, and get wider at the top, or vice-versa. Some doors just have it for a few feet, others are like this almost all the way around. In every case, it's only on one side, if that helps. Some of the gaps are about 1/4", a couple are big enough to stick your forefinger into.
We're running out of time in building this house. How do you think they would fix this? Here's a typical example:
Osmigo is offline   Reply With Quote
Old 05-09-2019, 08:20 PM   #2
retired framer
Rewards Points: 4,368
Re: Gap between door trim and jamb - fix?
I would have put a jam extension on it first. Spaced out with wood.
Do not use flat bottom gables with scissor trusses.
Old 05-09-2019, 08:33 PM   #3
Rewards Points: 18,204
Totally unacceptable!
Whoever install that trim could have just tapped down the sheet rock and made it fit tight to the jamb.
Old 05-09-2019, 08:43 PM   #4
Rewards Points: 992
Who would do that and think you'll be ok with it? Even with paint grade trim you can't leave that big of a gap and expect caulk to fix it.
NotYerUncleBob2 is offline   Reply With Quote
Old 05-09-2019, 08:49 PM   #5
retired framer
Is this a shear wall where there is plywood behind the drywall or is the drywall 5/8"
Old 05-09-2019, 11:25 PM   #6
Rewards Points: 1,138
What does the other side of that jamb and casing look like, specifically the gap between the casing and drywall?
ZEW496 is offline   Reply With Quote
Old 05-09-2019, 11:47 PM   #7
Hammered Thumb
Rewards Points: 704
I would second the opinion that the drywall could be 5/8" (measure that the door jamb is 4 9/16").
Did the GC install the doors, and there is a millwork sub? Looking at the mitered corner of the casing, it doesn't even meet. Remember, you hold the purse strings . . .
3onthetree is online now   Reply With Quote
Old 05-09-2019, 11:51 PM   #8
Contractor/Engineer
Rewards Points: 1,170
What? You're kidding, right?
There is no such thing as a trim carpenter.
There IS a finish carpenter and those are the guys that are supposed to install the doors, baseboard, trim, crown, window sills, etc.
IMO the doors should come out and then be installed correctly and be correctly trimmed. This would be an easy job for a pro - but unfortunately it would be repeat labor because of incompetence from the NON Carpenters that have been on-sie. - as if one is called a door-hanger or something and there they're followed by "trim" carpenters.
Sorry if I've stepped on any toes - but come on... there are well established and defined jobs when it comes to building a house and each other those skilled trades is supposed to be responsible for their jobs, including coming back and doing it correctly.
How can the inspector pass this crap?
Nealtw likes this.
Domo is offline   Reply With Quote
Old 05-09-2019, 11:58 PM   #9
Contractor/Engineer
Yes Nealtw - I have no doubt that you would have done the job correctly, just as any true finish carpenter would have done.
Thickness of the sheetrock or presence of plywood-faced shear wall is immaterial. A finish carpenter would install the jamb extension, square/plumb the door in the frame, shim and finish the trim. (Personally, I usually put on two legs of the trim on the extension and then put the door into the hole, that way, the trimmed side become flush automatically. I find that easier and faster when installing prehung doors.)
Guess I don't know what's going on in the field now-a-days...
Nealtw likes this.
Old 05-10-2019, 12:04 AM   #10
retired framer
From what I have seen here when they order pre hung doors you just tell them what the wall is, they come made to fit likely for pennies more.
Old 05-10-2019, 08:35 AM   #11
Rewards Points: 16
Thanks for the replies. Not sure where this is going to go. The doors were pre-hung. Builder gets them from McCoys. They were put in by a trim carpenter crew that does the doors, baseboards, etc. They are pretty good guys; the problem here seems to be something that was done wrong before they came in.
Will post updates later. Seems like the only way you can get reliable work from subs is to stand there and look over their shoulders 24/7.
Old 05-10-2019, 09:12 AM   #12
firehawkmph's Avatar
Rewards Points: 2,526
No excuse for this on a new house especially. Door jambs should have been ordered to fit the wall thickness. Like the others have said, looks like they may have used thicker drywall or else the drywallers did a sloppy job. I'd have them order the right sized doors (jamb thickness) and replace what's there.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 05-10-2019, 09:55 AM   #13
Hammered Thumb
Rewards Points: 704
They're called "trim" carpenters as slang all the time. And its not set in stone, most GCs like to do the finish work themselves anyway. Some guys will only trim out the stairs. Some are only brought in to do complicated coffers/shelving/etc. Homebuilding is not as defined as commercial. The wall thickness is part of figuring out who and what went wrong, so the OP can bring the hammer down in the right place.
mark sr likes this.
Old 05-11-2019, 01:56 AM   #14
Contractor/Engineer
Yes, I can believe a slang term might be common in some areas.
It remains obvious that the person that continued to install the trim when it was obvious it didn't fit right was neither a "trim" carpenter or a finish carpenter.
There is no defense for the way OP's trim was left.
But, as is shown in all aspects today - quality is not the concern, price and avoiding responsibility are. Sad.
Old 05-11-2019, 02:00 AM   #15
retired framer
I think that installer must have only sat thru half the demonstration at Home Depot.
Domo likes this.
Flushing jamb up with wall for casing danielrg Windows and Doors 6 05-20-2014 11:43 PM
Door Jamb width jam Haggis Windows and Doors 4 03-27-2014 09:32 PM
PVC to bottom of exterior door jamb jjrbus Carpentry 8 05-10-2013 02:35 PM
window jamb extensions too short. ideas? itsnotrequired Windows and Doors 5 04-24-2012 05:22 PM
Reducer scribed to fit door jamb? Please Help!! joemontana16 Flooring 1 03-14-2010 11:47 AM
