Exterior Epoxy - Carpentry - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By mark sr
Old 04-10-2018, 11:03 AM   #1
Exterior Epoxy
Looking for advice on which exterior epoxy to use when replacing damaged wood on window casings, seal and all exterior wood in general. What brands do you guys recommend? Which ones are the easiest to work with and that sand and take paint easily?
Wormy is offline   Reply With Quote
Old 04-10-2018, 11:42 AM   #2
JUSTA MEMBER
Rewards Points: 2,116
Re: Exterior Epoxy
It's not epoxy, but I have used P L construction adhesive for this and it holds up better than the wood to outdoors environment.
ED
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
Wormy (04-11-2018)
Old 04-10-2018, 01:24 PM   #3
RRH
Rewards Points: 1,402
Re: Exterior Epoxy
Just Bondo
The miniwax brand is just a more expensive version. The miniwax hardener can be used with any. Just in case you cant get all the rot out and to harden the old wood fibers for it to stick better.
Then use a primer before painting after you sand,
RRH is offline   Reply With Quote
The Following User Says Thank You to RRH For This Useful Post:
Wormy (04-11-2018)
Old 04-10-2018, 01:42 PM   #4
Rewards Points: 390
Re: Exterior Epoxy
Look at the Abatron wood epoxy this is a very good product.
ClarenceBauer is offline   Reply With Quote
The Following User Says Thank You to ClarenceBauer For This Useful Post:
Wormy (04-11-2018)
Old 04-10-2018, 04:30 PM   #5
retired painter
Rewards Points: 224
Re: Exterior Epoxy
I prefer to cut out the rotten wood and let in new wood. IF you don't get all the bad wood out prior to patching, the filler will fail sooner or later.
SPS-1 likes this.
mark sr is offline   Reply With Quote
The Following User Says Thank You to mark sr For This Useful Post:
Wormy (04-11-2018)
Old 04-11-2018, 03:38 PM   #6
Rewards Points: 442
Re: Exterior Epoxy
http://www.advancedrepair.com/archit...oxy_intro.html
This is the only thing I use. I've used just about anything you can think of on exterior and it all eventually fails. This stuff holds up fantastic and I have yet to see it fail or even shows signs of deterioration, popping, cracking, nothing.
As was already said, get as much rot out as you can and replace with wood whenever possible. I also use the above epoxy as a glue for patches.
KC_Jones is offline   Reply With Quote
Old 04-11-2018, 06:08 PM   #7
Rewards Points: 14
Re: Exterior Epoxy
Abatron is expensive for relatively small amounts but very good. Many pros use Bondo and it does fine too.
EdBoston is offline   Reply With Quote
Old 04-11-2018, 10:36 PM   #8
Koa
Rewards Points: 174
Re: Exterior Epoxy
Search West Systems Epoxy. Use either The 105 or G Flex with 410 flaring additive. Easy to sand (easier than Bondo). I’ve used tons of this stuff, it works really well. They have great tech help so you can call them for info.
https://www.westsystem.com
Koa is offline   Reply With Quote
Old 04-12-2018, 04:18 AM   #9
Master General ReEngineer
Bondo's Avatar
Rewards Points: 504
Re: Exterior Epoxy
Ayuh,...... Epoxy is a poor choice, as it's not UV tolerant,....
Bondo, based on polyester resin isn't as strong, but takes UV light better, longer,.....
Old 04-12-2018, 05:28 AM   #10
Koa
Rewards Points: 174
Re: Exterior Epoxy
It’s being painted so it doesn’t matter. Most epoxy applications are probably exterior; boats and surfboards, being two examples.
Old 04-12-2018, 11:31 AM   #11
Rewards Points: 442
Re: Exterior Epoxy
Funny, in the world of auto body, Bondo is well known as the worst polyester filler on the market. It might be one of the first, but it is far from the best.
Also most polyester fillers (including Bondo) contain talc, which loves to absorb water. To an extent putting Bondo on wood is like filling it with a sponge. Holding moisture against wood, IMHO is never a good idea as it can and will (I've seen it first hand) cause more rot.
Old 04-12-2018, 04:23 PM   #12
Bondo's Avatar
Rewards Points: 504
Re: Exterior Epoxy
Ayuh,..... So long as painted, I completely agree,.....
I mix my own putties, 'n fillers with various ground glass, 'n cabosil,.....
As well as other additives per application needs,...
