European Hinges With 1"x2" Cabinet Frame? - Carpentry - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 1 Post By Nealtw
  • 1 Post By Dave Sal
  • 2 Post By lenaitch
  • 1 Post By Tymbo
Old 05-21-2020, 11:58 AM   #1
Dave Sal's Avatar
Rewards Points: 598
European hinges with 1"x2" cabinet frame?
Hey guys,
I'm planning on building cabinet doors for my bathroom and kitchen to replace the builders grade doors that have seen better days. I want to use 1"x2" for the door frames. The European hinges seem to all require a 35mm hole, and it appears that this would fit into a 1"x2" frame but just barely. Just wondering if a 1"x2" frame is wide enough for these hinges. Thanks
Dave Sal is offline   Reply With Quote
Old 05-21-2020, 12:31 PM   #2
retired framer
Rewards Points: 13,094
Re: European hinges with 1"x2" cabinet frame?
If you are putting a panel in that frame with a dado at 1/4" deep, you are pushing your luck.
Dave Sal likes this.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
The Following User Says Thank You to Nealtw For This Useful Post:
Dave Sal (05-21-2020)
Old 05-21-2020, 12:44 PM   #3
Dave Sal's Avatar
Rewards Points: 598
Yes, that was the plan.
Old 05-21-2020, 01:16 PM   #4
retired framer
It's been more than 20 years since doing one, so don't take my measurements as fact.
I think the gap from the edge of the door to the big hole is 1/4" and the hole is 1 3/8" so the far end of the big hole is 1 5/8 from the edge, that would leave you with 3/8" for that 1/4" dado in a 2" board. Should work.
figure 7-14
Old 05-21-2020, 02:21 PM   #5
Dave Sal's Avatar
Rewards Points: 598
I'm going to use your measurements and double check if this will work. If not, I'll just use variable overlay hinges, which is what are on there now. Thanks for your input.
Nealtw likes this.
Old 05-21-2020, 09:05 PM   #6
Usually Confused
lenaitch's Avatar
Rewards Points: 1,800
Visually, would going with 2 1/2" rails work. Gives you a little more wiggle room.
Dave Sal and Nealtw like this.
_________________________________________
Custodis pacis
lenaitch is offline   Reply With Quote
Old 05-22-2020, 07:33 AM   #7
Rewards Points: 466
What hinges are you using? The cup drilling distance is critical to obtain the correct overlay and prevent binding. Also, are the cabinets face frame or frame less? If face frame, you have much more fudge room because the doors will be far apart.
If frame less, and you want 3mm door gaps( this is what euro hinges were designed for) cabinet side thickness will also be a factor to include.
Tymbo is offline   Reply With Quote
Old 05-22-2020, 11:03 AM   #8
Dave Sal's Avatar
Rewards Points: 598
I haven't purchased the hinges yet. I purchased the 1x2 wood for the stiles and rails for the bathroom cabinet doors but that's as far as I've gotten. I was looking at switching to European hinges on the face frame cabinets, but started wondering if the 1x2 would be wide enough to accommodate the 35mm hole for the hinge cup. I'll probably just use some variable overlay hinges in the bathroom and then use wider stiles and rails when I start working on the kitchen cabinet doors.
Old 05-22-2020, 11:12 AM   #9
Rewards Points: 466
The safest way to proceed is to buy your hinges and do a mock up of a door stile with the hinge mounted. Then you can determine your door sizes accurately.
