Door Jamb Odd Size. Where Do I Buy It? - Carpentry - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By jlhaslip
  • 2 Post By firehawkmph
  • 1 Post By Gregsoldtruck79
Old 01-21-2018, 12:44 AM   #1
Rewards Points: 6
Door Jamb odd size. Where do I buy it?
Hey all, im trying to hang a pre-hung interior door. So i went to Home Depot to get a 30"x78" pre-hung door and some other materials. When i got home to fit the door in the slot, i realized the door jamb is way to wide. It seems that all the doors Home Depot sells have a 4-9/16" door jamb, i need a 3-5/8" door jamb. Anyone know if Home Depot or Lowes sell them? I looked on Home Depot's website most of which have a 4-9/16 door jamb. Any help is appreciated.
Mikeywires is offline   Reply With Quote
Old 01-21-2018, 01:12 AM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Door Jamb odd size. Where do I buy it?
Disassemble the jamb, cut it a heavy sixteenth over size to allow for planing/sanding the sawmarks off, reassemble and install. Add casing.
Done.
Note: do not cut off the hinge side. You need that as a full size to allow for the hinge gains as they are from the factory.
mark sr likes this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
Mikeywires (01-21-2018)
Old 01-21-2018, 02:54 AM   #3
Rewards Points: 6
Done.
I am not in the capacity to disassemble, cut, and reassemble the door jam.
But thank you.
Old 01-21-2018, 04:13 AM   #4
JUSTA MEMBER
Rewards Points: 1,612
Might have to "special order" one for your application.
ED
de-nagorg is online now   Reply With Quote
Old 01-21-2018, 05:00 AM   #5
Rewards Points: 6
ED
How much do you think something like that would cost?
Old 01-21-2018, 05:19 AM   #6
JUSTA MEMBER
If you have not damaged the one that you bought, return it, and maybe pay up to 25% more.
I hope that you have not cut or nailed the first one.
ED
Old 01-21-2018, 10:24 AM   #7
firehawkmph's Avatar
Rewards Points: 2,550
Go to a real lumber yard. They can order a door with whatever size jamb you want. Just did that for a recent job. I needed 5 1/2" jambs. Cost $20 more per door. For Home Depot to special order anything it's usually more money, and a 50/50 chance they screw it up.
Mike Hawkins
de-nagorg and Nealtw like this.
firehawkmph is offline   Reply With Quote
Old 01-22-2018, 12:01 AM   #8
retired framer
Rewards Points: 6,224
Was 78" a special order.
I would just find someone with skillsaw skills.
Old 01-22-2018, 07:02 AM   #9
Rewards Points: 82
The old established lumber stores around here have a wood working shop in them. A person could drop the door jamb set off to them and they would rip it down to fit. May cost $35.00 but hey, just what is stress reduction worth ? JMO
de-nagorg likes this.
Gregsoldtruck79 is offline   Reply With Quote
Old 01-24-2018, 02:14 PM   #10
Rewards Points: 5,012
4-9/16" .? You mean 4-1/2" .?
If you live in a mobile home and need a 3-1/2" Wide x 78" Tall door jamb, you must go to a place that sells them.
If not, then you will have to alter the one from HD.
ron45 is offline   Reply With Quote
Sink Size Specs - Advice needed donvaz Kitchen & Bath Remodeling 1 08-12-2012 02:39 PM
wire size for 1575 inverter 15' from battery bluemoonshine Electrical 8 12-28-2011 10:49 AM
Rule of Thumb for Trowel size and Spacer size please.. K.M.G Flooring 7 02-08-2010 09:13 PM
Determining Boot/Register Size Earnie HVAC 15 12-31-2009 06:00 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 01:08 AM
