DIY Post & Beam Foundation!!! - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-25-2019, 02:06 PM   #1
Rewards Points: 2
Exclamation
I'm in the process of building my own home. Its going to be a small home no bigger than 600-800 sq. ft. and I'm having serious trouble on how to build a post and beam foundation! I have been researching and I want to use cinder blocks because I want it off the ground. But I don't know how to setup the posts for stability in the middle.
I've researched Larry Haun and his videos and saw how he did his posts but, what I didn't figure out was how he formed the base, middle, and how he connected the wood to the concrete.
Though, I just really need a proper way in doing my posts in the middle so i can get started on framing my floor.
MMW112 is offline   Reply With Quote
Old 01-25-2019, 02:54 PM   #2
retired framer
Rewards Points: 4,896
Re: DIY Post & Beam Foundation!!!
That doesn't sound like it should be anything to be confused about.
What are the outside measurements of the house?
how many posts are you planning on?
how high off the ground will you be?
what is the frost depth in your area?
How big are the footings you are planning for?
Post and beam foundation skirting bobby_d Building & Construction 8 03-10-2015 11:46 AM
L shaped porch framing onjtrainee Building & Construction 34 02-07-2015 08:10 PM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Modified post and beam framing question? diywengr Building & Construction 7 08-11-2010 09:18 AM
New deck - Gap between beam and post due to shrinkage? DaveNJ Building & Construction 3 07-06-2010 08:23 AM
