Custom Built Kitchen Cabinets - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree14Likes
Old 05-14-2019, 05:53 AM   #16
retired painter
Rewards Points: 446
Re: Custom built kitchen cabinets
Originally Posted by woodyg2060 View Post
The goal for me is to eliminate as many steps as possible thus the idea of the prefinished plywood.....
I'm looking for any ideas about finishing them in as simple and foolproof method as possible, that's why I was wondering if anyone has used Waterlox?
I've only used that brand a few times, which Waterlox product were you thinking of using? You can save a few steps by sanding and applying the 1st coat or 2 of finish prior to assembly. The final coat should always be applied after assembly.
mark sr is offline   Reply With Quote
Old 05-14-2019, 06:24 AM   #17
Rewards Points: 22
I was thinking of the original product which I think is a semi gloss or their satin finish. I was ruminating on the idea of a few coats on the 1x3 maple before I even started building and then on the face frames before attaching them to the carcasses. I think one reason Waterlox is not used more is because of the smell that lingers for weeks.
I also saw some folks using the paint thinner/oil base urethane/linseed oil mixture. I saw some equal parts 1-1-1 mixture and some 3-2-1 ratios. If I went with the unfinished ply maybe I could just roll on 2 or 3 coats of the 3-2-1 mixture before Ieven start cutting up the plywood?
Sent from my SM-J320V using Tapatalk
woodyg2060 is offline   Reply With Quote
Old 05-14-2019, 07:04 AM   #18
Rewards Points: 1,930
Don't get too stuck on pocket hole assembly. Sides need to be held fairly precisely and pocket holes need lots of jigs to hold the sides. You can also nail the face frame for precise fit instead of preassembling it. One nail every 12" or so as long as box and the frame are fairly straight. Then really anchor the face frame with pocket hole screws from the open back. Then add finished 1x4 top and bottom frames on inside of the box (for hanging) then cover the back with 1/4" ply. Easier is glue, 16 ga x 1.5" finish air gun then finish with predrill/countersink screws, fine thread drywall screws are convenient for joints that will not be seen.
You will not be using very many plywood. It is possible to pick fairly flat and good face birch or oak plywood from even box stores. Plan early and take your time picking stocks. Try to store them flat indoors, garage is good. Then finish one face by rolling one coat of amber shellac then sand lightly with 150 or so sandpaper. This leaves a smooth surface which you can finish with another coat of urethane (maybe even without sanding again) once the box is assembled. This way, you don't have to worry about scratches, damage fillers, etc during construction.
woodyg2060 likes this.
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
woodyg2060 (05-14-2019)
Old 05-14-2019, 07:10 AM   #19
retired painter
Rewards Points: 446
Waterlox has both polyurethane and rubbing oil finishes. Boiled linseed oil is along the lines of a rubbed on oil finish. It doesn't dry properly if applied straight out of the can - it needs to be cut in half with paint thinner first. Adding linseed oil or any oil to poly will slow down the drying time and isn't recommended.
The Following User Says Thank You to mark sr For This Useful Post:
Old 05-14-2019, 08:03 AM   #20
Rewards Points: 22
Originally Posted by Nealtw View Post
So one long cupboard for a wall that might include the sink the corner and a bank of draws or whatever. All one piece.
If I go with the corner sink layout I would build a bottom in place and put cleats on the wall for the counter top. I would just build a frame for corner sink "cabinet"
Old 05-14-2019, 08:23 AM   #21
retired framer
Rewards Points: 13,768
They built cupboard in place in the 40s
This is a simple box build.
Do not use flat bottom gables with scissor trusses.
Old 05-14-2019, 09:44 AM   #22
Two Knots's Avatar
Rewards Points: 3,231
I'm looking for any ideas about finishing them in as simple and foolproof method as possible, that's why I was wondering if anyone has used Waterlox? Thanks again.
We built our kitchen cabinets about twelve yeas ago. (quartersawn and
rift dawn white oak) Finished them with
regular Waterlox. Since then we re-waterloxed them two times...
the last time was about 6 weeks ago...
That is the beauty of Waterlox. We washed the cabinets
well, for re-finishing there is NO sanding needed, we first
removed the knobs and maked sure that
the cabs were thoroughly clean. Then we ragged on the waterlox with a clean
soft cloth like a undershirt. The cabinets came out beautifully, they look
brand new. When you first apply the waterlox itís a bit shinny, after several
weeks it tones down.
Note: the first time we applied the waterlox after the build, we gave the
cabs three coats...for the two refresher applications we only used one coat.
FYI...We rag on almost all our stains and poly or waterlox finishes. We get an
even coverage without any drips.
Behind every clever man is an astonished woman!
*Joann*
Dogs love me, men fear me!
Two Knots is offline   Reply With Quote
Old 05-14-2019, 10:07 AM   #23
Two Knots's Avatar
Hereís the amazon link to waterlox.
https://www.amazon.com/s?k=waterlox&...f=nb_sb_noss_1
Forgot to mentioned before doing the waterlox ( for the first time) we
used boiled linseed oil and waited the recommended three to four days
for the BLO to dry before applying the stain...
On the two waterlox refresher applications...we just cleaned the
cabs thoroughly.
*Joann*
Old 05-14-2019, 10:35 AM   #24
Rewards Points: 22
cabs thoroughly.
Two Knots, thanks for da info! What Waterlox(sheen) product did you use?
Old 05-14-2019, 10:39 AM   #25
Rewards Points: 22
Thanks for the vids! I was going to build similar boxes! I think the first vid he used prefinished ply. I figured I might need about 11 carcasses. I was going to assembly line everything and bang through them. Cut up all Plywood first. Then build all frames etc. Try to get a finish on everything best I can before they're assembled.
Dave Sal and Nealtw like this.
Old 05-14-2019, 12:28 PM   #26
Still learning every day!
F250's Avatar
Rewards Points: 746
If you use all 3/4 material for sides, tops, and bottoms, I would simply screw them together with 2-1/2" long construction screws (star, or Torx drive) using only butt joints. The screws will never be seen, and its a very simple and strong construction technique. The same screws can be used to mount the carcasses to the wall cleats and toe-kick structure as well.
Pete
Bark less, wag MORE, and Show Compassion to everyone you meet!
F250 is offline   Reply With Quote
Old 05-14-2019, 01:33 PM   #27
Rewards Points: 22
Thanks, not a bad idea. It eliminates the need to drill as many pocket holes. Also I keep saying I am using 1x3 for the rails and styles but I'm actually using 1x2 .
Old 05-14-2019, 02:10 PM   #28
Two Knots's Avatar
Woody, it just says Waterlox original. I see you mentioned poplar.
I would not recommend Poplar, itís hard to finish (in my opinion)
as compared to other wood. If you thinking of using part Poplar
and part maple, donít do it. It would be impossible to get a good
stain match.
I knew we could build nice cabs...however, the finishing part
kept me awake nights. I think we managed to get a nice finish.
minwax oil based stain...I blended two stains together, english chestnut
and pecan...Then did a lot of research and used Waterlox for the finish.
I just took these pics today. As I said, we refreshed the waterlox ( I just
looked it up, we did it Mid March) so, this is after the waterlox toned down...
it had a lot more shine to it several weeks ago. The rails and styles are
3/4Ē and the floating center panels - we resawed to 1/4Ē thick.
We used euro hinges on the galley kitchen part( first pic)...by
the time we got to the breakfast room area - we used regular hinges on the TV cabinet
and the spice cabinet (second pic) ...we had them on hand so we used them.
Note: the waterlox applied with a rag gives a nice even finish, no
shiny parts and after a few weeks it even looks better...
if you want a pic of the can, Iíll get the can and show you a pic.
Custom built kitchen cabinets-45976703-34d2-417a-ab3e-3a351ab68058.jpg   Custom built kitchen cabinets-98013f3b-1503-44f5-8c14-a6900f27a81f.jpg
*Joann*
Old 05-14-2019, 03:19 PM   #29
Rewards Points: 22
stain match.
i think original is semi gloss. Prob what I'll use. Very nice! Great shape! Classic style, always classy. I'd use birch ply from the plywood supplier if I didn't get the finished maple ply.
Old 05-14-2019, 06:08 PM   #30
hkstroud's Avatar
Rewards Points: 5,530
Most sink bases incorporate one or sometimes two false draw fronts directly in front of the sink.
Those can be made to tilt out with a small tray mounted to the back side. Very convenient for sponges, brushes and even bar soap.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
The Following User Says Thank You to hkstroud For This Useful Post:
Building custom cabinets for a bar? gizzygone Carpentry 12 03-24-2015 09:24 PM
Kitchen cabinets - Are Ikea cabinets good? What other mfgs have you used? whataboutj Kitchen & Bath Remodeling 24 11-09-2012 06:14 PM
Are Kitchen Cabinets Secure richard7994 General DIY Discussions 6 11-06-2011 06:21 PM
Upper Kitchen Cabinets latemoy Carpentry 3 09-13-2011 06:31 AM
Replace kitchen tile without moving cabinets and countertop stubits Tiling, ceramics, marble 7 02-18-2010 10:56 AM
