Curved Summerhouse Roof - Carpentry - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Jdwevs
  • 1 Post By SPS-1
Old 06-29-2020, 11:29 AM   #1
CUVED HOBBIT HOUSE ROOF: I am taking on the ambitious task of building a summerhouse. I want it to be like a hobbit house but am struggling with a way of getting a curved roof which I can then AstroTurf. It will be about 15ft wide and 8ft deep. I’m considering cutting the front and back of the house and then using slats that can then be felted over and the grass on top but not sure about this method yet. Any suggestions very gratefully received.
Jdwevs is offline   Reply With Quote
Old 06-29-2020, 11:37 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,390
Re: Curved summerhouse roof
Why not just do a green roof? i.e. living roof.
Old 06-29-2020, 11:58 AM   #3
retired framer
Rewards Points: 15,544
Originally Posted by Jdwevs View Post
CUVED HOBBIT HOUSE ROOF: I am taking on the ambitious task of building a summerhouse. I want it to be like a hobbit house but am struggling with a way of getting a curved roof which I can then AstroTurf. It will be about 15ft wide and 8ft deep. Iím considering cutting the front and back of the house and then using slats that can then be felted over and the grass on top but not sure about this method yet. Any suggestions very gratefully received.
Have you access to a picture of something similar
Something like this?
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 06-30-2020, 07:16 AM   #4
I would happily do that is I can get it to attach to the steepest section. Will look at that. Thanks.
Old 06-30-2020, 07:18 AM   #5
it won’t be symmetrical but one side will be like this....
https://www.google.co.uk/amp/s/www.c...wooden-wonders
Old 06-30-2020, 07:31 AM   #6
retired framer
figure 7-14
Old 06-30-2020, 07:38 AM   #7
retired framer
figure 7-14
Old 06-30-2020, 07:46 AM   #8
Originally Posted by Nealtw View Post
Very interesting thanks!
Nealtw likes this.
Old 06-30-2020, 08:15 AM   #9
retired framer
Any gluelam companies near by, you would only need 2 for the front and 2 for the back and run the rafters like joists between them.
figure 7-14
Old 06-30-2020, 08:27 AM   #10
Rewards Points: 10,806
For a rookie, it might be easier to laminate pieces cut from plywood. Probably higher material cost, but the process looks pretty straightforward.
https://www.instructables.com/id/Wooden-Arches/
Nealtw likes this.
SPS-1 is offline   Reply With Quote
Old 06-30-2020, 09:16 AM   #11
That looks good too. I guess I could use one of these methods and then a cladding roof.
