Crown Width To Beam Size - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-19-2014, 06:22 PM   #1
Rewards Points: 145
Crown width to beam size
I'm starting to add crown to my house. I have 8' ceilings and 7.5" baseboards including base cap. I thought 3.5" standard crown seemed a little small. I bought some 4 5/8" crown and was wondering if it would be balanced on this beam that is in a hallway. The crown is roughly half the size of the beam. Any problems with this look?
kjmass1 is offline   Reply With Quote
Old 11-19-2014, 06:34 PM   #2
Rewards Points: 18,118
Wide crown is going to make the room look shorter.
Old 11-20-2014, 02:32 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,578
im with joe. such large crown is going to be too dominant on the beam too. the next size down would be better.. really small crown is too small for wall to ceiling junction its better suited for accent trim on furniture or for boston headers
woodworkbykirk is offline   Reply With Quote
Old 11-20-2014, 05:49 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 234
I agree with both Joe and Kirk.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 11-20-2014, 07:31 PM   #5
Rewards Points: 145
Thanks for the input. I'll put this in the living room instead which won't feel as narrow and cramped.
sizing a roof steel beam to span 15', OR equivalent size for 3-ply 11-7/8 LVL DIYguy2000 Building & Construction 8 07-28-2014 05:22 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
what size beam do i need naulleau Building & Construction 5 04-27-2012 12:28 AM
Which beam is stronger? D270 Building & Construction 19 04-19-2012 08:17 AM
What Size Crown Molding? Jim McClain Interior Decorating 1 10-04-2010 08:16 AM
