Crown Moulding Gap To Ceiling -up To 3/4" - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 04-13-2019, 04:57 PM   #16
retired framer
Rewards Points: 4,734
Re: Crown Moulding Gap to Ceiling -up to 3/4"
Originally Posted by finisher65 View Post
I never mentioned caulking a 3/4" inch gap. I still think there is plenty of room to even it out with mud despite the light being close in that 1 area.
Shouldn't you ask how far it is to the wall on the right first. That would be one lump of filler if you have 6 ft over there.
Do not use flat bottom gables with scissor trusses.
Old 04-13-2019, 05:24 PM   #17
Rewards Points: 106
The OP says the gap is about 3' long as much as 3/4 " in 1 spot. That's what I responded to. Contractors remodeling high end houses would ask me to fix things like this, including removing the trim on the can light to float it as far as necessary, while I was already on site drywalling & or doing plaster repairs.
It does take skill & yes, so does caulking. Like you, I've seen a lot of caulk damage done with good intentions.
finisher65 is offline   Reply With Quote
Old 04-13-2019, 06:01 PM   #18
retired framer
I didn't see the 3 ft. You would do some filling with quarter inch and then float it out, not that my floating would be much better than looking at the gap.
Old 05-04-2019, 12:32 AM   #19
Rewards Points: 282
Isn't this where scribing comes into play?
Jamesonc is online now   Reply With Quote
Old 05-04-2019, 09:32 AM   #20
Naildriver
chandler48's Avatar
Rewards Points: 866
Scribing the crown will enhance the mistake. See post 9.
Jamesonc likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 05-04-2019, 01:34 PM   #21
Rewards Points: 7,487
Impossible to tell without detailed photos or on site look.
If a shoe base or small cove molding can be purchased in the exact same finish it might be possible to cover the gap and fool the eye. There would still be some uneven reveals but all the way up near the ceiling I don't think even you would notice them after a while.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
Bowed Ceiling Crown: Install or Return? Twister Carpentry 9 12-07-2018 01:18 PM
Should I add crown moulding to cabinets? NickWa Interior Decorating 5 11-26-2011 08:47 PM
Crown moulding with a vaulted ceiling? cstrat Carpentry 34 06-17-2011 07:51 PM
Need help on Crown Molding on inset Trey Ceiling pacumming Carpentry 2 01-30-2010 01:13 AM
Crown Moulding and nailing davis_mc Carpentry 21 01-12-2010 11:52 PM
