Chair Rail Returns - Carpentry - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By XSleeper
Old 06-29-2020, 06:48 PM   #1
Chair rail returns
Can someone please walk me through how to make a return on chair rail? I’m so close to being through with my first wainscoting!
Msboy_96 is offline   Reply With Quote
Old 06-29-2020, 08:54 PM   #2
I cut my pieces at a 45 bevel but I’m having problems fitting it against the wall.
Old 06-29-2020, 08:59 PM   #3
retired framer
Rewards Points: 15,110
Re: Chair rail returns
Originally Posted by Msboy_96 View Post
I cut my pieces at a 45 bevel but Im having problems fitting it against the wall.
That should work, what exactly is the problem? Maybe a picture or two.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 06-30-2020, 12:17 AM   #4
Rewards Points: 1,713
I stand the moulding up like the miter saw fence is the wall. Cut it square first. Lets say you are making a return for the right end of your moulding. Cut a 45 left, off of a long piece of trim with the intent of using the piece you cut off as your return. The piece you cut off needs to be a perfect triangle when viewed end-on. If it's too short the return wont reach the wall. If it's too long, it will have a little flat part left on back and being too long it will push the chair rail away from the wall. Cut slowly as the blade finishes the cut and let the piece gently fall away. (The blade likes to fling those small pieces at your co-workers which really pisses them off).
Once you have the perfect triangle return cut, then you can swing the saw around and cut a 45 right, and glue them together. You usually want to use some 23 ga pin nails to help hold it into the glue. Or just tightly tape it up for 15 minutes or so. Some guys just shoot the large piece on and then they force the return in along with some glue and let friction hold it.
Nealtw likes this.
XSleeper is offline   Reply With Quote
Old 06-30-2020, 08:49 AM   #5
Rewards Points: 4,320
Is your corner exactly 90?
huesmann is offline   Reply With Quote
Old 06-30-2020, 09:55 AM   #6
Hammered Thumb
Rewards Points: 2,156
https://www.familyhandyman.com/proje...-a-chair-rail/
3onthetree is offline   Reply With Quote
