Building Walking In Pantry Closet Unded Coffer Ceiling - Next To Cabinets Help - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-27-2019, 09:40 PM   #1
Rewards Points: 214
Building Walking In Pantry Closet Unded Coffer Ceiling - Next to Cabinets help
10' ceilings. going to have coffer ceilings that run in the entire kitchen area and in this "butlers pantry" area. they are 6"H,
I have a few options for how I run the coffer perimter as well as the height i build the closet or distance i build it off the wall.
the base cabinets come out standard 24", uppers, standard 12". The uppers are 36"H, so the top will be at 90" before crown. the closet door, I can get at 80" or 96", and i can build it out or up however much i want.
I thought it would look cool, to only put a standard 6'8" door, build the closet at 96 or 102", and 26" off the wall (so the counter runs against it. then have the coffer perimeter run behind the cabinets/closet against the wall.
I could also build out a soffit above teh cabinets at 12" the 26", and run the perimter to that and build the closet to the ceiling.
or i can put the closet door flush against the wall, etc.
alot of options, not sure what will look best, any body have any ideas on this?
Building Walking In Pantry Closet Unded Coffer Ceiling - Next to Cabinets help-butlerpantry.jpg
moneymm22 is offline   Reply With Quote
Old 04-27-2019, 10:49 PM   #2
retired framer
Rewards Points: 62
Re: Building Walking In Pantry Closet Unded Coffer Ceiling - Next to Cabinets help
I would build it out the 26" and up to the ceiling and the Question is do you run the box into the side or go around it. Keep the door at 80"
Do not use flat bottom gables with scissor trusses.
Old 04-27-2019, 10:57 PM   #3
Rewards Points: 214
what about over the cabinets?
if closet goes up to ceiling at 120" and the doors right around the hallway are all 8', shouldnt i match those heights?
Old 04-27-2019, 11:04 PM   #4
retired framer
Rewards Points: 62
If they are in the same room, if not it would be your choice, almost all the house we did with 7 or 8 ft doors, the doors chanced to 80" as soon as you got out of the entrance hall.
Old 04-28-2019, 09:00 AM   #5
Rewards Points: 152
This is strictly my observation but such ceiling would be the first thing people notice, and it would deserve the attention. As such, it would look the best if it wasn't broken by minor cabinets or appliances. I'd build 10' wall for the pantry and wrap the ceiling around the walls and keep the cabinet away from the ceiling.
carpdad is offline   Reply With Quote
Old 04-28-2019, 10:33 AM   #6
Rewards Points: 214
If I kept the height of the closet at 96” and didn’t build soffit over the cabinets I would have 2 feet of clear space for the perimeter of coffee to run to the wall behind cabinets /closet.
This was my plan A. No good?
Here is my bad iPhone edit sketch.
Building Walking In Pantry Closet Unded Coffer Ceiling - Next to Cabinets help-e0812fde-a6b5-41b8-8466-a7391747f5af_1556461981543.jpeg
Old 04-28-2019, 11:50 AM   #7
Rewards Points: 214
here are some views if i did the closet to the 10 foot ceiling and soffit over the cabinets but only 12" deep.
Building Walking In Pantry Closet Unded Coffer Ceiling - Next to Cabinets help-3dview.jpg
Old 04-28-2019, 12:11 PM   #8
retired framer
Rewards Points: 62
You do know there is no right or wrong way to do it, it is all about what you and the little lady agree to.
Old 04-30-2019, 09:21 PM   #9
Rewards Points: 152
I think the top of the pantry could look odd, as if there was a loft. You could wrap the pantry wall with veneer/trim and stain to match the cabinet next to it, but a pantry size cabinet could look odd as well. One way to search could be a website such as Houzz which has many photos.
Building partition wall behind base cabinets bluefitness Building & Construction 3 11-09-2010 07:49 PM
Building Out a Closet acme54321 Building & Construction 2 06-03-2010 08:43 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Removing Closet / Building Wall beespost Building & Construction 1 10-23-2009 06:15 PM
DIY kitchen cabinets all the way to the ceiling? Jeremy Hillary Boob, PhD Carpentry 7 01-14-2009 07:42 AM
