Building New Floor, On Existing Concrete And Steel - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-14-2014, 05:52 PM   #1
Rewards Points: 4
Building new floor, on existing concrete and steel
Hello all,
I've been planning to build a new floor over an existing empty space in my attic. The space is approximately 12 feet wide by 16 feet, and I plan to use the space simply for light storage. I've read the calculators regarding the pro's and con's of 2x6 vs 2x8 and I am set on building with 2x8.
My question really lays in support and attaching to the concrete below. Its a dining room below, with various openings and windows. I think my best bet is to build an outline around the room with 2x8 and then cross the 12 foot span with 2x8 placed every 16 inches.
I've uploaded a few photos, but It appears I can't send links. I'll try replying with the link after.
Anyone got any thoughts on my project?
Thanks so much,
Mike
xmichael is offline   Reply With Quote
Old 12-14-2014, 08:26 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,578
if your going to be using 2x8 joists i wouldnt be going 16" o.c i would do 12" o.c and install 2 rows of blocking.. the floor will sag if its 16" o.c
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
xmichael (12-14-2014)
Old 12-14-2014, 08:43 PM   #3
Rewards Points: 4
12 inches apart
photos at http 64.94.15.40/ floor/
Yes, I had planned to do them run them 12 feet in length, spaced every 16 inches, but it sounds like what you are saying is even at 12 feet in length i should space them every 12 inches.. Thanks for your comment!
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
concrete piles for 40 X 60 steel building Darryl N Building & Construction 0 05-21-2012 10:32 AM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
New construction on existing steel building burton Building & Construction 6 03-30-2010 04:22 PM
