Best Way To Terminate Base Shoe At Doorway Trim - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 01-13-2020, 01:04 PM   #16
Hammered Thumb
Rewards Points: 718
Re: Best way to terminate base shoe at doorway trim
yeah +1 on just attach it to the baseboard. 1 to 1 1/2" is a big gap for the drywall to be raised above the floor, especially if just one bottom plate. Hopefully your baseboard is at least 5 1/4" high, if not you would need a backer to match the drywall thickness to prevent the baseboard from angling in at the bottom.
3onthetree is offline   Reply With Quote
Old 01-13-2020, 01:17 PM   #17
Rewards Points: 44
Its Speed Base... 7 1/4 high. There is a double bottom plate so it is covering the top one. Partial of the bottom exposed. But you guys are saying to use shorter Nails then I can do that.
Nealtw likes this.
RetroJoe_1 is offline   Reply With Quote
Old 01-13-2020, 01:54 PM   #18
retired framer
Rewards Points: 4,406
I would have put something to fill the space with something like plywood but to late I guess.
Do not use flat bottom gables with scissor trusses.
Old 01-14-2020, 01:01 PM   #19
Rewards Points: 2,196
To each his own, but I prefer to use Banak shoe molding in a wood grain rather than painted.
To me, it looks like a better transition.
ktkelly is offline   Reply With Quote
