Base Board Over Tile - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-19-2018, 02:01 PM   #1
Mike Milam's Avatar
Rewards Points: 146
Base board over tile
I have a hill to climb here. Attached is a photo of an alcove where I will be putting in a 60 X 36 whirlpool tub. The pony wall on the left is the wet wall. After the tub is in I will drywall the surrounding area with green board and tile up about 12 inches. I plan to take the tile all the way to the door facing and down to the floor. I plan to put baseboard at the floor from the tub to the door facing. My concern is the thickness of the tile will make the baseboard stand proud of the door facing at least 1/4 inch. How would you guys address that? Bevel the end of the baseboard at the door facing? Other ideas? Thanks
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is offline   Reply With Quote
Old 03-19-2018, 02:07 PM   #2
retired painter
Rewards Points: 322
Re: Base board over tile
I'd either shim out the door casing a 1/4" or set the tile on top of the baseboard. Or you could skip the base altogether.
mark sr is offline   Reply With Quote
The Following User Says Thank You to mark sr For This Useful Post:
Mike Milam (03-19-2018)
Old 03-19-2018, 02:10 PM   #3
Mike Milam's Avatar
Rewards Points: 146
Thank you! I hadn't considered not using baseboard. I could just put 1/4 round from the door to the tub. I was stuck on finishing the seam where the tile met the floor.
Old 03-19-2018, 03:23 PM   #4
Naildriver
chandler48's Avatar
Rewards Points: 1,936
To address the original question, yes, bevel the molding, then flat cut the end to where it reveals the 1/4" you need to sit back in the door molding indentation.
But I like Mark's answer and go without the base altogether.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
Old 03-19-2018, 09:34 PM   #5
Rewards Points: 712
You can tile the wall first, below the floor tile level but with expansion/shrink space, then finish with floor tiles. Wet saw with sharp blade gives you a good edge and maintain even grout joint. File the cut edge smooth. You should use cement board against the tub. Greenboards will soak up water. Cement board with redguard coats is about the best.
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
Old 04-02-2018, 08:55 AM   #6
Mike Milam's Avatar
Rewards Points: 146
Slight change in plans. How would it look to set the baseboards at both ends all the way to the tub and end the tile at the baseboard when it comes down? I have now decided not to tile the wall all the way to the door. I plan to bring the tile out to the edge of the pony wall and do the other end out the same distance from the tub. I feel the two ends would look better symmetrical.
Base board over tile-master-tub-baseboard-2.jpg   Base board over tile-master-tub-baseboard-1.jpg
Old 04-02-2018, 09:57 AM   #7
retired painter
Rewards Points: 322
Sounds like a plan.
Mike Milam (04-02-2018)
Old 04-02-2018, 10:13 AM   #8
retired framer
Rewards Points: 9,128
You will be doing the little return on the base?
Nealtw is offline   Reply With Quote
Old 04-02-2018, 10:17 AM   #9
Mike Milam's Avatar
Rewards Points: 146
Umm it will dead end against the tub. Where do you think a return should apply?
Old 04-02-2018, 10:24 AM   #10
retired framer
At the end of the tile near the door
And where it ends to cover the edge of the tile at the stub wall.
Old 04-02-2018, 10:28 AM   #11
Mike Milam's Avatar
Rewards Points: 146
Oh, sorry I wasn't clear. The base will wrap the stub wall from the tub to the vanity (other side) and the base will go from the tub to the door facing. The tile on the door wall (for lack of a better description) will only come out about 4 inches from the tub. I no longer plan to tile that wall all the way to the door.
Old 04-02-2018, 10:35 AM   #12
retired framer
Ok
Tub, tile, baseboard, door
Tub, tile, baseboard with return where it meets tile then door.
Old 04-02-2018, 03:39 PM   #13
Mike Milam's Avatar
Rewards Points: 146
Like so. The tile will come down to the baseboard.
Using Cement Board for Shower Base PKC General DIY Discussions 2 12-17-2015 08:48 AM
Porcelain tile over particle board over concrete slab? roughtrader Flooring 9 04-16-2012 11:24 AM
4 wire thermostat-electric base board RONBO Electrical 5 03-19-2012 01:35 AM
5/8" Fireboard (Paint) meets 1/2" Cement Board (Tile) LeviDIY Building & Construction 9 02-09-2010 09:41 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
