Attic Door/stair Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-12-2015, 03:28 PM   #1
Rewards Points: 37
Attic door/stair question
I am going to install an attic door/stair in my farm work shop to get up into the trusses. The second floor loft is 7'2" from the deck floor to the ceiling.
I have not been able to find an attic door stair assembly made that is close to my fixed dimension.
The closest one I can find is an adjustable one that says it's minimum height is 7'10".
Is there a problem with installing it and shortening the ladder at the foot end? The Lowe's guy said that it won't work.
Any helpful hints appreciated!
Much obliged,
mustang Gregg
PS The unit I picked up is a Louisville #A2210.
Mustang Gregg is offline   Reply With Quote
Old 04-12-2015, 07:26 PM   #2
Rewards Points: 18,244
Not a problum, but unless those trussed are built for storage they should not be top loaded.
Unconditioned Attic Insulation Question Daveparks Insulation 11 01-31-2014 08:42 PM
Unconditioned Attic Insulation Question Daveparks Insulation 0 01-28-2014 10:25 PM
Question: BNC cables through attic (studs to wall, or ceiling drywall?) eatmyturf Electrical 4 04-05-2013 11:25 PM
(Partial) Radiant Barrier Above Finished Attic? Lascaux Insulation 11 09-26-2012 08:56 PM
Attic Venting/Insulating Question gregt848 Building & Construction 1 11-25-2007 03:33 PM
