Adding Grill Deck - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-12-2018, 03:16 PM   #1
Rewards Points: 2
Adding Grill Deck
I'm seeking advice on whether to use footings or concrete blocks for this project. My worry with footings is the depth--the long side of the deck in the attached picture will slightly overlap septic lines. I do plan to attach the grilling deck to the bottom stair and stair support posts (and I've read if it's going to be attached, then use footings). Can I get away with concrete blocks? If I definitely need footings, how deep should the holes be?
prestonwilliams is offline   Reply With Quote
Old 07-12-2018, 03:22 PM   #2
retired framer
Rewards Points: 16,998
Re: Adding Grill Deck
You need more than one post before posted pictures show up.
The footing depth is the local frost depth for your area.
If you are attaching to a structure that does have footing. you should have footings.
If it is free standing and you can put up with a little movement from one year to the next the footing aren't so important.
Nealtw is offline   Reply With Quote
Tags
deck , floating deck , footings
Deck over roof --Help, I need product to repair roof w/o deck tearoff jaes Roofing/Siding 5 08-09-2017 04:34 PM
Deck Staining Nightmare steven994 Painting 7 06-14-2017 04:56 AM
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
Running CSST outside to grill on deck... tigerbalm2424 HVAC 6 11-06-2008 10:07 PM
