Thread Tools |
Rewards Points: 12
![]() 5/16th lag bolts into 2x4 studs
Hello all,
I'm putting up some shelves in our garage using the brackets below http://m.homedepot.com/p/Unbranded-2...8?N=5yc1vZbbzo I'm thinking of using three 5/16 lag bolts to screw the brackets into the studs because their thickness matches the size of the bracket holes. Also, I figured that 3.5 inch length would be good as they would go almost 3 inches into the studs (the drywall is half inch) But I'm wondering if bolts this big May weaken the studs? What do you think? |
Sponsored Links | |||
Advertisement |
Advertisement |
Jello Wrangler
Rewards Points: 539
You'll be fine. Predrill and hit as close to center.
Advertisement |
Rewards Points: 4,796
I have the exact brackets in my portable workshop, I just used 2" deck screws.
Rewards Points: 12
Thanks for the reassurance!
Advertisement |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Jacking Exterior Wall / Replacing Sill Plate | Pittsville | Building & Construction | 7 | 06-14-2017 09:18 AM |
Load bearing section - gap in studs | AppleMac*Fit | Building & Construction | 21 | 08-09-2012 02:32 PM |
Help with straightening studs before drywalling | genEus | Carpentry | 3 | 08-29-2008 03:12 PM |
How difficult is it to learn to use metal studs? | YerDugliness | Building & Construction | 7 | 08-18-2008 07:59 PM |
using 8' studs vs 7'-9" studs | RINAIL | Carpentry | 2 | 07-10-2008 05:16 PM |
