16' Tall One Story Truck Repair Shop - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-21-2015, 03:34 PM   #1
Rewards Points: 8
16' tall one story truck repair shop
Hello,
We are looking to build a repair shop for cars and trucks. It needs to be 55' by 35' and 16' high.
Can it be done with regular wood framing? Is it to high? What method should we use?
I would appreciate your help.
Thank you.
scprod is offline   Reply With Quote
Old 06-21-2015, 04:18 PM   #2
Retired Moderator
Rewards Points: 7,174
A pole building is possible and cheap---
light steel also--
Standard framing might be possible using 2x6---is this in a commercial zoned area? The local building department might be your best starting point.
We have some builders and architects here---someone will help.
scprod (06-21-2015)
Old 06-21-2015, 04:30 PM   #3
Civil Engineer
Rewards Points: 5,246
Certainly it can be done. I used to work in a converted leather factory, four story building framed entirely in heavy timber, built for massive loads. The question is not can it be done, but what is the most efficient (cost effective) way to frame the building. That is best answered by the building designer, who must take into account the use, loading, applicable codes, and cost of construction. And getting that type of information from an internet chat forum like this is a tall order. Best of luck with the project.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
scprod (06-21-2015)
Old 06-21-2015, 07:35 PM   #4
Rewards Points: 18,260
I'd be concidering a steel building on a raised slab.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
oh'mike (06-21-2015), scprod (06-21-2015)
Old 06-21-2015, 08:11 PM   #5
World's Tallest Midget
Mort's Avatar
Rewards Points: 696
Usually that's the way I see commercial buildings done anymore.
I hate signatures.
Mort is offline   Reply With Quote
The Following User Says Thank You to Mort For This Useful Post:
scprod (06-21-2015)
Old 06-21-2015, 09:02 PM   #6
Rewards Points: 8
oh'mike
Thank you for the reply. Its an agricultural zone.
We want to do it all in wood. Pole building looks like the way to go, with 6x6 post...
Old 06-21-2015, 09:23 PM   #7
Rewards Points: 8
joecaption
We will have a raised slab but want to use only timber.
Old 06-21-2015, 09:27 PM   #8
Rewards Points: 8
Daniel Holzman
Thank you for the advice. I was looking to do everything my self. 16' seems high for a framed wall. It would be heavy to lift ans the spam would be 35' for the roof. So i was looking at other possibilities.
Old 06-21-2015, 09:30 PM   #9
Retired Moderator
If you have AG zoning, then the pole building is a great choice---I was planning on building one some years ago---and I could not build it any cheaper than the pole building erector---so check the 'Do IT Yourself' price and the built price.
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 01:42 PM
Chain saw given late rights by repair shop oh'mike Tools 3 07-04-2011 10:41 PM
Truck window repair waltman Automotive Repairs 1 07-03-2011 09:16 AM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Two story porch repair PRK Carpentry 1 08-08-2009 01:53 PM
