#1 Vs #2 Pressure Treated - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-24-2016, 03:18 PM   #1
Rewards Points: 28
#1 vs #2 Pressure Treated
Im building a deck and am getting conflicting info on the difference between #1 and #2 PT. Home Derpo person said that #2 is ground contact and stronger. An internet search says it has to do with less knots and quality, and that #1 is of higher quality.
Is all PT ground contact?
mudslinger is offline   Reply With Quote
Old 05-24-2016, 03:40 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 160
Re: #1 vs #2 Pressure Treated
The HD guy is wrong. #2 or #1 is the quality. #1 is better. Not all PT is rated for ground contact. Most is not. It must specifically be labeled ground contact. I don't think HD carries it.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
mudslinger (05-26-2016)
Old 05-24-2016, 03:57 PM   #3
Oso954's Avatar
Rewards Points: 620
My HD carries some ground contact PT. it's primarily 2x planks. No 4x or 6x stuff that you might use for skids.
In my store, it's all Hem-Fir PT.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Old 05-24-2016, 04:15 PM   #4
kwikfishron's Avatar
Rewards Points: 140
Just to second what rjniles just said, the HD guy couldn't be more wrong (imagine that).
Look on that tag that's stapled to the end of the board, that will tell you whether it is or is not. And you are correct about the #1 being a better quality board than the 2's although there is nothing wrong with #2.
I have no problem framing a deck with #2 and then use #1 for the decking itself because generally their better looking boards.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 05-24-2016, 04:46 PM   #5
Rewards Points: 28
OK then thanks. I noticed that a 2x8x16 is 5 bucks less a board at HD than the quote that a lumber yard gave, but everything the lumber yard quoted is ground contact.
This begs the question if ground contact for beams and joists is a good idea or overkill. I do overbuild generally. It is a northern elevation deck. Will eather perform better in terms of mildew?
Old 05-24-2016, 06:30 PM   #6
Civil Engineer
Rewards Points: 5,246
I only use ground contact when the wood is actually touching the ground. I do like to cover the tops of the joists and beams with ice and water shield. Some on this forum think that is a waste of time, but I think it extends the life of the lumber.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Old 05-26-2016, 01:26 PM   #7
Rewards Points: 28
Thanks to all, ill never outlive ground contact or not, but maybe for the kids ill go with the lumber yard ground contact since they did the quote and its not much more dough. The quest for decent boards begins.
Old 05-26-2016, 01:49 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 160
IMO when buying PT for above ground use, quality and appearance is what counts.
Old 05-26-2016, 02:38 PM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 17,370
As I understand it, the grade refers to the number of knots in a given length. #1 will have less knots and is typically spec'd for joists and rafters.
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
Old 05-26-2016, 04:01 PM   #10
Rewards Points: 28
Got the ledger #2 GC from the lumber yard. Tough to find decent boards. May have to look at Home Depot closer, since they carry #1 above ground. Im not going to struggle with huge bows and twisting.
Old 05-26-2016, 04:10 PM   #11
A "Handy Husband"
rjniles's Avatar
Rewards Points: 160
I would never again us PT for decking. Pay the price and use TREX.
Old 05-26-2016, 04:17 PM   #12
Rewards Points: 28
Too much. Ill suffer with pt. We've downsized and im already overimproved. Trex gets awfully hot also and demands upkeep.
Old 05-26-2016, 08:17 PM   #13
Rewards Points: 114
I'm redoing my deck surface and the lumber yard stocks only prime lumber. HD and Lowe's only had lower grade. I didn't ask but I doubt the deck boards and 2x are ground contact which deals with the amount of preservatives used on the lumber. #1 #2 prime etc deals with the quality of the board.
My HD has regular and "premium" that are about 50 cents and a dollar a linear for respectively. The higher quality stuff from 84 was price $18 for 16' of 5/4 but with quantity the guy for it down to $16.50. As soon as I for the delivery I could see the difference! Will always use them when I can
bcemail is offline   Reply With Quote
pressure treated wood project -- acceptable quality? bunchofquestion Building & Construction 6 11-09-2011 10:17 PM
Prep work to stain new pressure treated wood joemessner Painting 0 08-20-2011 06:39 PM
Shoddy Pressure Treated Lumber? spanky77 Building & Construction 17 06-25-2011 09:09 AM
Hybrid Deck - Is Pressure Treated + Composite Feasible? kyassassin Building & Construction 4 01-15-2009 09:33 PM
pressure treated or pre-stained?? farrington135 Landscaping & Lawn Care 2 05-03-2007 10:04 AM
